Chromecast Audio
The chromecast is set to full range. Both Jriver and tidal flow through it the same way.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Just found this thought it was interesting.
When Chromecast Audio is connected through an optical interface (see here for compatible cables), it will always use Full Dynamic Range. Setting Full Dynamic Range to OFF won't have an effect as it will remain ON.
I am guessing that this is a recent change via a software update...or you were really drunkLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
