CD Player biting the dust?
kevhed72
kevhed72 Posts: 5,149
My Teac CD player just started making a lot of noise when a CD is loaded into it....a spinning noise If that makes any sense. A CD player wasn't on the upgrade list since I just bought a DAC....so any ideas??
  • lightman1
    lightman1 Posts: 10,797
    edited August 2016
    Buy an Ayon CDP. No more worries. ;)
    What vintage is this CDP? And has the transport ever been cleaned/dusted?
    txcoastal1 Posts: 13,514
    Rip and stream
    Do you have a spare PC???
  • lightman1
    edited August 2016
    Valid point, Ron. But there are those of us who still prefer drop and spin media.
    Thoughts?
    Well it wasn't in the budget :'( , So what would be the budget?....hence the question about a spare PC
    He's got a DAC
  • kevhed72
    What are the odds I can take it apart and fix it myself? I have too many discs to do the PC thing....
    Well...We all have to many disks
    But your going to bust her open and see what the culprit might be, Jesse, Rich, or FGTV(Fred) and others would probably be best to answer, but will probably need more details
    Ya gotta a model number,,,Parts may not be cost effective vs replacing the unit
  • rpf65
    rpf65 Posts: 2,127
    You're afraid of breaking an almost broken CD player?
  • lightman1
    :o
    rpf65 wrote: »
  • BlueFox
    BlueFox Posts: 15,250
    kevhed72 wrote: »
    Slim to none, but possible if you get lucky. Just rip 5-10 a week, starting with your favorites, and soon you will have more music than you can listen to.
    lightman1 wrote: »
    Seriously? When did your salary get upgraded to CEO class, Russ? Nice player but not for us bottom feeders, lol
  • Joey_V
    Joey_V Posts: 8,600
    lightman1 wrote: »
    Can you buy me an Ayon CDP?
    F1nut Posts: 51,855
    Which model? Does it do it with every disc? Will it read and play?
  • [Deleted User]
    [Deleted User] Posts: 10,716
    I have a Toshiba SD-4960 (no remote) that does SACD
    and sounds surprisingly good. I was going to dynamat
    it but haven't found a need for it yet. PM me if interested.
  • kevhed72
    edited August 2016
    Teac CD 1000
    It will read and play....and it does make the noise with every disc....
  • K_M
    K_M Posts: 1,631
    1. Rip your CD's
    2. Get a used player at Goodwill or Salvation army
    3. Get a new player (blu ray or DVD) at any store
    4. Get a used player on Ebay (Cd, Bluray, or DVD)
    As to fixing it......unless it has something so specific or nostalgic about it, not sure it would be justified.
  • [Deleted User]
    1. you should get your CD player fixed of course. (nice DAC)
    2. my suggestion was only as a stop gap.
    3. good luck.
  • kevhed72
    kevhed72 wrote: »
    Teac CD 1000
    It actually makes a clicking noise as the disc spins...
  • K_M
    K_M Posts: 1,631
    kevhed72 wrote: »
    kevhed72 wrote: »
    Teac CD 1000
    aah, thought it was an older vintage model. I would repair it.
    Could be quite simple. Literally something loose, or simply touching disc when spinning.
    Eitther way good luck!
  • kevhed72
    I popped the top and played a disc.....it appears the discs wobbles a bit when played, which may be making noisetpl71at0khfx.jpeg
  • kevhed72
    Alright....unscrewed the top piece to take a look and put it back together.....perhaps the small disc on top was out of alignment.....but I put it back together and it works fine. Any recommended maintenance to the transport while I have this thing open?
  • [Deleted User]
    you could add a separate PS for the analog section :#
    F1nut Posts: 51,855
    kevhed72 wrote: »
    The small disc on top is supposed to be able to move around a bit, it's got some slop. It's also magnetic and locks onto the spindle motor disc when the player loads the CD. Sounds like yours got jammed a little cockeyed, likely because a CD was crooked on the tray when loaded.
    Add Dynamat Xtreme to the plastic cross support on top of the transport, but do not put any on the tab pointing towards the rear. Add more Dynamat Xtreme to all that bare metal inside the chassis.
  • kevhed72
    kevhed72 wrote: »
    Thanks for the info....I would like to keep this transport for awhile since I just invested in a DAC.
  • BlueFox
    Good job. It's always nice when the fix is something simple. Hopefully it's permanent versus temporary.
  • boston1450
    boston1450 Posts: 7,758
    Its nice to save $$$ also. Good job Kev.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • kevhed72
    Well, poking around in there gave me an idea....perhaps Upgrade the power supply and any caps in the digital section....since I will be using this unit with a DAC....as well as Dynamat the inside. Is this unit worth the time and effort in terms of the transport itself? Thoughts?
    tonyb Posts: 33,071
    Is it worth it ?
    In my opinion, no. Why ?
    Because a lot of cd spinners, good ones, are pretty cheap these days considering many are moving to digital playback.
  • kevhed72
    tonyb wrote: »
    Is it worth it ?
    I decided against that idea due I felt fortunate to have it running smoothly again....I did Dynamat the inside for kicks.....per Jesses advice. I also added 2 separate pieces on either side of the magnetic disc on top. I thought about one piece but didn't want to risk the adhesive touching the disc itself. This was actually easier than I thought...for an OCD person actually fun
    F1nut Posts: 51,855
    edited August 2016
    Looks good. On the top cover, you don't want to run it out to the front and back edges like you have because the goo tends to creep and will stick to frame making it very difficult to remove the cover.
  • kevhed72
    Funny you both say that....it just seized up on me so I took the cover off. It was a bit tight to get off but not too messy. The disc loads fine but reads NO DISC. It looks like a new optical eye runs about 20.00 on EBay.....this would be my best guess as to the issue. I bought the unit 2nd hand here awhile ago and have put a good number of spins on it myself. I hope it just needs a new eye....
