Pass Labs X1 on Audiogon
This damn pre amp is built as robust as the 500i. very impressive.
Well that was a cruddy review
I can't find any information about what difference there may be between these 2 connection point. Any information would be appreciated. Thanks -
If you are looking at the two serial ports on the power supply, they are both the same. I chose to use the outboard connector.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thank you John. I appreciate it.
Remember to just set it up and walk away for 48 hours... You can also download a copy of the manual from Pass.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Also if you could post a review of the pass XA30.5 you picked up too please!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I do have a copy of the owner's manual but saw no mention of the dual serial ports. Seems odd to have to ports. I will post a review for sure. Thanks
nooshinjohn wrote: »Remember to just set it up and walk away for 48 hours... You can also download a copy of the manual from Pass.
+1 You will experience an unnecessary wave of buyers remorse if you listen to the X1 before it settles in for a couple of days.
After it settles in, you will spend endless hours playing different material you haven't listened to in a long time and set in amazement at the level of detail and presence the music now has that wasn't there with your old setup.
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Can't stress more to make sure you turn it on and walk away for awhile before playing anything.
Same when you get the amp.
Where is the dam n review or some initial impressions at least.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The amp is still in transit. It will be delivered next week.
One of these amps is available local-ish. I have a very itchy trigger finger for this amp. Trying to be patient. What speakers are you driving them with?2 channel:
Theater:
I will be using Paradigm Signature 8's and I have Signature 6's too.
Ah yes that's right. You did mention that earlier.2 channel:
Theater:
Now I know you are chompin' at the bit for a review as the Paradigm specs pretty much match your Focal's...hehehehe2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Oh man... Trying to be patient. Lol, I followed H9's recommendation, bought a few tubes. It DIDN'T help! But, I might save more cash and pick up something much nicer in the coming months. Not to say the pass isn't nice.2 channel:
Theater:
The pass lab preamp is non functioning. Going back to pass for service. Great customer service from Desmond @ Pass. First class all the way and no charge just pay the shipping. I can handle that. Just wanted to update the thread.
That is very rare. Pass gear has an extremely low failure rate. But, they are tops in CS...........just about the best there is. I'm sure other boutique companies are just as good........unless you go by the moniker Polkfarmboy, then all bets are off.
H9Post edited by heiney9 on"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
The build quality of the Pass Labs products are second to none that's for sure. I look forward to hearing this combination.
Pass X1 will be back in the house this Friday. Time to warm it up again. I will let John chime in about what the issue was. Thanks
And I will say Pass customer service is second to none and I will send them a token of my appreciation. I like the way they do business. -
Ask them to have Nelson sign it... It looks really cool that way. Also, connect everything BEFORE plugging in the power cables and never touch anything on the back without waiting 5 or 10 minutes after unplugging the power section from the wall. Bad things can happen...
I sent the above shortly after I learned about the failure. I feel horrible for not mentioning this tidbit of information before you took it out of the box. That said, you are soon in for a real audio treat.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I received the X1 back today and it is rocking. Kent at Pass said fire it up and the soundstage will just get wide in time.
I am blown away at Pass Labs customer service. This is the way to win a customer for life. Very professional from first call to receiving the package just this hour.
Have a nice weekend.
No Nelson signature?
Glad she is finally home and coming up to speed. give it a few days to settle in and give is some of your thoughts. Congrats!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
All I will say so far is holy ****. Thanks This amp has plenty of power too.
Very nice man, looks built like a tank. Let us know how the sound progresses as it breaks in.HT SYSTEM-
lsi 9's -
I am totally happy with this new combination. The amp has plenty of power which blows me away. The pass X1 pre is exactly what I was hoping for. I want to thank John for the lead into this X1. Paired with the pass amp is a great combination and pass customer service is second to none.
It's very difficult PITA for a lot of the respected well known gear. Most are based on regions, possible exclusive deals already in play, minimum orders, and you practically have to beg....and/or all of the above.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
