How to flatten albums left in 100 degree heat?
Dabutcher
Left my new two record set of the sound track to my favorite animated classic "Heavy Metal" in my van on front seat for two days in 110 degree heat in a sealed van. Now warped badly. It was looking in perfect condition and clean too. As always. Any help would be greatly appreciated. Peace. D
Try this if you're desperate.
https://www.youtube.com/watch?v=ibsutUWfG-M
There are also devices you can buy to flatten LPs but they're stupid expensive. As in thousands of dollars.
http://hifiheaven.net/shop/Furutech-DF-2-LP-Flattener-115V?language=en¤cy=USD&gclid=CPassZzNiM4CFQyUaQodW3oMywafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Here's a cost-effective solution:
http://www.musicdirect.com/p-3528-furutech-df-2-lp-disc-flattener.aspxJay
Global warming.
I was looking into the VinylFlat product for a while. Read some mixed reviews, watched a few videos. Looks like it might work, but it's a lot to spend to possibly damage your records further. On the other hand, if it's warped to being unplayable, you don't really have anything to lose? I have a couple of rare affected albums needing attention, but still haven't gotten around to trying this.
In all of the controlled warming techniques I've read about so far, the key points seem to be:- Low heat with relatively short exposure times
- Controlled cooling with the album under compression
- Patience enough to endure multiple "properly conducted" flattening sessions, and not just rushing to higher heat and longer sessions to hurry the process.
I disabled signatures. -
If it's still hot in Minneapolis today put album in sleeve sandwiched between two sheets of plexiglass and set a couple of heavy cinder blocks on top and sit out in the sun for an afternoon this method has worked for me on ocassion.Home Theater
Thanks.
MIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?” -
Dab, as others have suggested, the Furutech flattener is a good professional tool. If you search around, there might be a record shop, or record service which does cleaning/demaging/flattening of lp's in your area. If you're a member of a local audio forum or club, that would be my first port of call, then maybe ask around your local record shops. Or if you have a big collection of vinyl, you might want to invest in your own machine. Cheers.
I just looked in the archives, I must have gotten rid of my copy as too beat up...
I have a lot of Albums in the garage. no problem so far... it is very hot in there. thank God they are not all ruined. I wish I had a Album Rack like ted(reeltrouble1 has)PolkAudioClyde
I use two 1/2" thick 13" x 13" square plates of tempered glass. Sandwich the album between and leave them in the sun for an hour or two, (you can use the oven, but I'm chicken), depending on how hot your sun is. Check it so it doesn't get melting hot, seems to work OK on the two I've tried...VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
More details please, Mista B.
Where'd you get the glass?
What's "works okay" mean? Did it flatten the records? How bad were they warped before? And now?
I want to try this. But I'm chicken.I disabled signatures. -
Got the glass from the glass guy through work, he beveled the edges so you can separate the plates easier.
The records were warped at the one edge, maybe an inch in as if stored on a slant in heat if that makes sense. Light warp otherwise. It did flatten them out, yes, that one wouldn't play on the outside song, it made the needle hop, now I can play it.
I've read you can flatten gooves out if you're not careful (melting) but I figured who cares, can't play it anyway as is... I haven't tried one with a lighter "all over" kind of warp.
Just sat it inside on the living room coffee table in the sun and checked on it a few times, eventually it flattened out, so I moved it into the cool basement (still between plates) to cool, presto!
I wouldn't experiment with something you love, but if you've got something that has to have it, great candidate. Definitely a YMMV, I'm no expert, but I did stay at Holiday Inn this year.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Hahaha
Fantastic. So you did yours indoors then? I wouldn't have thought you could get it warm enough that way, but then again, it doesn't take much to warp them in the first place. The main album I'd be want to do this with currently costs on average $80 - $110 to replace. I'd like to have a method to use as needed moving forward, though.
Any sense of how hot it got, or for how long you left it?I disabled signatures.
