PS Audio Soloist with Ethereal Faceplate
F1nut
This is a used PS Audio Soloist CI with an Ethereal faceplate. The faceplate has slight discoloration at the bottom left corner area. You can see it at times depending on the light, other times you can't see it. The price reflects this. Other than that, it works perfectly.
Edit: I forgot to mention it comes with a double gang box, ready to install.
$60.00.
Shipping, USPS Priority Flat Rate insured is $13.45. I have a non-Priority box I could use to ship. This may be less or more depending on location, but does not include insurance regardless.
PayPal
$60.00.
PayPal
@F1nut would this be a problem to install and then connect a APC H15 into out of curiosity....
I know it would be double filtered but just curious....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I use the Soloist and a UPC-200 together, which is double conditioning, so I don't think using your APC would be an issue.Political Correctness'.........defined
President of Club Polk -
I am finishing a basement currently. Unfortunately, I'd have to redo the outlets a bit to accommodate this, as the drywall is already up.
Where does this ship from, if I may ask? -
MarylandPolitical Correctness'.........defined
Bada bump....bada boom
You are getting power conditioning and a Power Port for about the price of a new Power Port alone.
You want a different colored LED installed, say blue? I can do that.Political Correctness'.........defined
If you can do a blue LED consider it sold, just PM me your paypal or if you prefer a check just let me know.
-Sonny -
You got it. I can even give you a choice of blue, which I can let you know about when I get home.Political Correctness'.........defined
Sounds good, now all I need to find is a DAC to pair up with my mac mini and amarra. lol
Ok, choices are 430nm, 10mcd, 40 degree. This is a blue/violet, it's not a bright light. 470nm, 320mcd, 90 degree. This the brightest. 466nm, 100mcd, 45 degree. Still bright, but not as.Political Correctness'.........defined
Think the last one might be the best option, my OCD would like to match it as close as possible to my Pioneer Elite gear.
Ok, that should be close.Political Correctness'.........defined
Done. It's actually a prettier blue than the pic shows.
Good sale, and really great customer service. Nicely done.
That looks about as close as it gets if not right on. Can you mod my Xbox One and mac mini now?
Yep.Political Correctness'.........defined
SOLDPolitical Correctness'.........defined
Dang Jess, I thought you were a hoarder when it comes to all things PS Audio. If you plan on parting with any premium outlets, give me a shout.HT SYSTEM-
lsi 9's -
Dang Jess, I thought you were a hoarder when it comes to all things PS Audio. If you plan on parting with any premium outlets in mauve or puce, give me a shout.
Fixed that for you.
........ probably shouldn't have but .........
Fixed that for you.
Sal Palooza -
LMAO....can always count on ya man.HT SYSTEM-
