Looking for speaker stands for FXiA6's
Hey guys. So, giving that these are triangle shaped, Im having trouble finding speaker stands for them. Sure I could use a regular square base and secure them, but does anyone know of any triangular stands? Or maybe something that I could use the wall mounts on?
Thanks for your suggestions!
    gudnoyez Posts: 8,161
    Are you using these as rear or side surrounds? Nice surrounds by the way mine are as sides on end tables on each side right at ear level. I to had difficulty finding stands for them, end tables were the best alternative and I don't have to worry about them getting knocked over.
    F1nut Posts: 51,771
    If you can find a used pair the Sanus Ultimate Foundation stands are perfect for the FXiA6's.
    Don't you mean these ones I looked for these a while back they are discontinued, you got a lead on any?
  • These will be used as rears in a 5.1.4 setup.
    Thanks for the suggestion on the Sanus stands. I do notice the base is 6x6 1/2 thus about square. Thats pretty common. I guess Ill have to go with those or have a woodworking friend of mine make a custom setup.
    F1nut Posts: 51,771
    gudnoyez wrote: »
    Yes those. No, I don't have any leads.
  • gp4jesus
    gp4jesus Posts: 2,019
    consider these to wall mount your FXis:
    http://www.cotytech.com/content-product_info/product_id-2278/side_clamping_bookshelf_speaker_wall_mount_sp_os06.html
    w/33 lb capacity I used them to wall mount, @ ~40 degree angle(!), a pair of RTi A3s as surrounds
    Tony
    *all connected w/Premiere ICs
  • gp4jesus
    Tony
  • gp4jesus
    gp4jesus wrote: »
    Tony
    As good as those are you can't mount FXIA6 to those mounts as the A6s are rectangular and they would not hold, my A3s are mounted like yours the A6s are on end tables at ear level the Sanus stands pictured would be perfect forthe OPs or mine A6s for that matter.lrfxo460tdqd.jpg
  • gp4jesus
    Sorry. I haven't seen FXi A4/6 live & in person.
    I think (incorrectly?) one could use these to wall-mount almost any speaker.
    Enjoy!
