Pass Labs X1 on Audiogon
2
  • WagnerRC
    WagnerRC Posts: 2,209
    This damn pre amp is built as robust as the 500i. very impressive.
    txcoastal1 Posts: 13,519
    WagnerRC wrote: »
    Well that was a cruddy review :(
  • WagnerRC
    I can't find any information about what difference there may be between these 2 connection point. Any information would be appreciated. Thanks
    nooshinjohn Posts: 25,988
    If you are looking at the two serial ports on the power supply, they are both the same. I chose to use the outboard connector.
  • WagnerRC
    Thank you John. I appreciate it.
    edited June 2016
    Remember to just set it up and walk away for 48 hours... You can also download a copy of the manual from Pass.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Also if you could post a review of the pass XA30.5 you picked up too please!
    2 channel:
    Theater:
  • WagnerRC
    I do have a copy of the owner's manual but saw no mention of the dual serial ports. Seems odd to have to ports. I will post a review for sure. Thanks
  • dpowell
    dpowell Posts: 3,081
    edited July 2016
    +1 You will experience an unnecessary wave of buyers remorse if you listen to the X1 before it settles in for a couple of days.
    After it settles in, you will spend endless hours playing different material you haven't listened to in a long time and set in amazement at the level of detail and presence the music now has that wasn't there with your old setup.
    heiney9 Posts: 25,494
    Can't stress more to make sure you turn it on and walk away for awhile before playing anything.
    Same when you get the amp.
    Where is the dam n review or some initial impressions at least.
  • WagnerRC
    The amp is still in transit. It will be delivered next week.
  • mikeyb128
    One of these amps is available local-ish. I have a very itchy trigger finger for this amp. Trying to be patient. What speakers are you driving them with?
    2 channel:
    Theater:
  • WagnerRC
    I will be using Paradigm Signature 8's and I have Signature 6's too.
  • mikeyb128
    WagnerRC wrote: »
    Ah yes that's right. You did mention that earlier.
    2 channel:
    Theater:
    mikeyb128 wrote: »
    WagnerRC wrote: »
    Now I know you are chompin' at the bit for a review as the Paradigm specs pretty much match your Focal's...hehehehe
  • mikeyb128
    Oh man... Trying to be patient. Lol, I followed H9's recommendation, bought a few tubes. It DIDN'T help! But, I might save more cash and pick up something much nicer in the coming months. Not to say the pass isn't nice.
    2 channel:
    Theater:
  • WagnerRC
    The pass lab preamp is non functioning. Going back to pass for service. Great customer service from Desmond @ Pass. First class all the way and no charge just pay the shipping. I can handle that. Just wanted to update the thread.
    edited July 2016
    That is very rare. Pass gear has an extremely low failure rate. But, they are tops in CS...........just about the best there is. I'm sure other boutique companies are just as good........unless you go by the moniker Polkfarmboy, then all bets are off.
    Post edited by heiney9 on
  • WagnerRC
    The build quality of the Pass Labs products are second to none that's for sure. I look forward to hearing this combination.
  • WagnerRC
    edited July 2016
    Pass X1 will be back in the house this Friday. Time to warm it up again. I will let John chime in about what the issue was. Thanks
    And I will say Pass customer service is second to none and I will send them a token of my appreciation. I like the way they do business.
    Ask them to have Nelson sign it... It looks really cool that way. Also, connect everything BEFORE plugging in the power cables and never touch anything on the back without waiting 5 or 10 minutes after unplugging the power section from the wall. Bad things can happen...
    I sent the above shortly after I learned about the failure. I feel horrible for not mentioning this tidbit of information before you took it out of the box. That said, you are soon in for a real audio treat.
  • WagnerRC
    edited July 2016
    I received the X1 back today and it is rocking. Kent at Pass said fire it up and the soundstage will just get wide in time.
    I am blown away at Pass Labs customer service. This is the way to win a customer for life. Very professional from first call to receiving the package just this hour.
    Have a nice weekend.
    No Nelson signature?
    Glad she is finally home and coming up to speed. give it a few days to settle in and give is some of your thoughts. Congrats!
  • WagnerRC
    edited July 2016
    All I will say so far is holy ****. Thanks This amp has plenty of power too.
    Very nice man, looks built like a tank. Let us know how the sound progresses as it breaks in.
  • WagnerRC
    I am totally happy with this new combination. The amp has plenty of power which blows me away. The pass X1 pre is exactly what I was hoping for. I want to thank John for the lead into this X1. Paired with the pass amp is a great combination and pass customer service is second to none.
  • footwedge
    footwedge Posts: 475
    @DSkip
    Just curious. What process does a retailer have to go through to carry certain brands ?
    footwedge wrote: »
    @DSkip
    It's very difficult PITA for a lot of the respected well known gear. Most are based on regions, possible exclusive deals already in play, minimum orders, and you practically have to beg....and/or all of the above.
