Can there be more that one accepted answer to a question, and is there an order?
I'll answer as 1, 2, 3, 4, and accept as 2, 4, 1
Best Answers
Answers
  • pkquat
    pkquat Posts: 748
    Accepted answers are in post order.
  • lightman1
    lightman1 Posts: 10,796
    A little too early in the morning to be this drunk.
  • JPete
    JPete Posts: 295
    woah
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
    F1nut Posts: 51,750
    That "answer" deal really screws up the flow of a thread. Another part of the nightmare known as Vanilla. Please don't use it.
    txcoastal1 Posts: 13,512
    I hate the answer button
    It throws you back up to the top of the thread :#
  • lightman1
    In with 16. Thanks!
  • pkquat
    pkquat Posts: 748
    Agreed and noted for future questions. On some forums if you have more than one best answer it either only allows 1 or it puts the last one you selected to the top, and sometimes will not allow you to re-select an answer to change the order. They kept the original thread order and often put the thread post number with the answer.
    I like that the best answer(s) are at the top, but not that vanilla re-orders the thread. Very poor design.
    F1nut Posts: 51,750
    The best answer as selected by the OP may very well not be the best answer and therefore someone else seeking information may be mislead. The "answer" button is a bad idea any way you look at it.
  • decal
    decal Posts: 3,205
    I thought I was wrong once, but I was just mistaken.
