RTI10 Midrange Speaker is getting too much low end and distorting.
Answers
    F1nut Posts: 51,760
    I don't know what that means.
    It means your speakers are 3 decibels down at 35Hz, which means they are not capable of producing the low bass you desire. Get a sub.
  • dekuda
    dekuda Posts: 756
    Add a quality sub, set speakers to small, xo at 80. It will take the load off the AVR & make all the difference in the world.
    +1 on that. It makes a big difference if you have a good sub
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • gp4jesus
    gp4jesus Posts: 2,019
    No point in that as they are the same speaker in different style cabinets.
    not quite. While they both lack mid HP filtering - the chief cause the mid's "gymnastics," their XOs have less than subtle differences. BTW: my 'A7s' mids had the same issue full range WITH quality power playing Donald Fagan's "The Nightfly." Using a 150hz bass blocker as a jumper on one side may fix the problem but, like tonyb said, you may not like the results.
    To the OP, unless you get a power amp you will have to set the 10's to small and use a sub to handle the bass. I use the RTiA7's in my HT rig, set to small with a sub and have never had the issue you speak of.
    even w/a power amp I'd add a sub & set them to "small" and live happily ever after.
    Tony
    *all connected w/Premiere ICs
  • erniejade
    erniejade Posts: 6,321
    Have you tried running the speakers without dps? No processing. What is your result then?
    I have a set of rti12 running on a pioneer sc27 for ht. But once in a while listening to music on them. Tske the dsp off.
    tonyb Posts: 33,072
    Given the OP's musical preferences, I agree with this. However, I don't think he's looking to spend the additional coin.
