help choosing outdoor in-ceiling speakers
Hello, I want to purchase two in-ceiling speaker to be installed outdoors in a porch/gallery. I was thinking in the RC80i since it indicates "suitable for high moisture areas like bathrooms or even under eaves of an enclosed porch".
Can the V80 be an option for this application? which one would your recommend?
thanks!
thanks!
Are you coastal? If not then you should be fine. Just make sure they are far enough back from wind driven rain2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
...and of course, as long as your not in the wintery north.
