help choosing outdoor in-ceiling speakers
seba007
seba007 Posts: 1
Hello, I want to purchase two in-ceiling speaker to be installed outdoors in a porch/gallery. I was thinking in the RC80i since it indicates "suitable for high moisture areas like bathrooms or even under eaves of an enclosed porch".
Can the V80 be an option for this application? which one would your recommend?
thanks!
    txcoastal1 Posts: 13,513
    Are you coastal? If not then you should be fine. Just make sure they are far enough back from wind driven rain
    tonyb Posts: 33,072
    ...and of course, as long as your not in the wintery north. ;)
