NAD C-270 power Amps
KLapinas
Selling an excellent sounding NAD C-270 power Amp
Includes box and manual
Local Pick Up Preferred, but can ship at buyers expense
Mechanicsburg, PA
Asking $325
I have a 2nd non-working unit in excellent condition asking $100' goes in to protection mode when you turn it on
Continuous Average Power Output into 8 Ω 120W (20.8dBW)
(Min. power per channel, 20Hz - 20kHz both channels driven with no more than rated distortion)
Rated distortion (THD 20Hz-20kHz) 0.03%
Clipping power (max. continuous power per channel) 140W (21.5dBW)
IHF dynamic headroom at 8 Ω 2.4dB
IHF dynamic power 8 Ω 210W (23.2dBW)
4 Ω 340W (25.3dBW)
2 Ω 450W (26.5dBW)
Damping factor ref. 8 Ω 50Hz >150
Frequency response 20Hz-20kHz +/-0.3dB
3Hz/70kHz -3dB
Input impedance R and C 20kΩ / 300pF
Input sensitivity ref. rated power 1.1V
Voltage gain x 28.3 (29dB)
Signal/noise ratio A weighted; ref. 1W >100dB
A weighted; ref. rated power >120dB
Bridged (Monophonic) Mode
Continuous Average Power Output into 8 Ω 300W (24.8dBW)
(20Hz - 20kHz both channels driven with no more than rated distortion)
IHF dynamic headroom at 8 Ω 2.2dB
IHF dynamic power 8 Ω 600W (27dBW)
IHF dynamic power 4 Ω 800W (28.5dBW)
Physical Specifications
Dimensions (W x H x D) 17 1/8 x 5 3/16 x 13 13/16"
(435 x 132 x 350mm)
Net weight 24.8 lbs (11.2kg)
Shipping weight 31.3 lbs (14.2kg)
Mechanicsburg, PA
Asking $325
4 Ω 340W (25.3dBW)
2 Ω 450W (26.5dBW)
3Hz/70kHz -3dB
(435 x 132 x 350mm)
Bump
Bump
Open to reasonable offers -
Bump
SOLD Locally
