A Couple of Firsts - And Look What Followed Me Home LSIM705's
  • MrBuhl
    MrBuhl Posts: 2,419
    Thanks Cathy! I agree its great to see that kind of interaction!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • D2Lo
    D2Lo Posts: 352
    Because it is an actual rubber, not a synthetic, it can dry out just a little over time. I have a pair here and after about 4 years I noticed a little white residue on it. Just the natural rubber drying out a bit. Any car care type conditioning product should get it back to its original if you spot that. You don't need to do it on the regular, but if you see any discoloration, that will take care of it.
    F1nut Posts: 51,920
    edited May 2016
    Michael, that white residue can be cleaned off with original Windex. It's caused by oxidation, not because the rubber is drying out. The same butyl rubber was used on the Monitor and SDA speakers, which are still going strong 30+ years down the road.
    In fact, the rubber around the engine on Ed's speakers showed some funky white marks, which I removed easily with Windex.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Mine came out of the box with white powder on those rubber rings. Windex worked for me.
    2 channel:
    Theater:
  • vmaxer
    vmaxer Posts: 5,120
    This is rubber blooming, some info for you. You can also Google it.
    http://www.hitechseals.com/includes/pdf/Rubber_bloom.pdf
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ interesting read @vmaxer ^^ Very insightful - thanks for sharing!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    F1nut Posts: 51,920
    So, neither oxidation or drying out......excellent. Thanks Billy.
  • vmaxer
    vmaxer Posts: 5,120
    No problem, I have worked in the rubber and plastics field all my life. Automotive supplier, gaskets and valve covers mostly.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
