Looking for Dreadnaught
trav0810
I am going to be needing a dreadnaught cable for a pair of SDA 3.1 TL's so that I can run them with a pair of Carver 7t monoblocks. If anyone has one, or is making them...let me know!
The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
Thorens TD320
Modified Carver C-1
Sent you a PMVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
If still looking after speaking with MrB, David Shirly makes them - @westmassguy
http://www.dhsspeakerservice.com/
I disabled signatures. -
I have spoken with MrB. He told me about Westmass guy as well. I had never looked for these before, so I didn't realize the expense that goes into building them.
I may look more towards a more inexpensive AI-1 cable if I can find one.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
White Lightning Moonshine DIY Speaker Cables and Interconnects -
I have an AI-1 that I purchased from Polk Audio around the turn of the century. I'm using it with my 3.1TL's
I too would like a dreadnaught but have no idea the cost. What are we talking about? -
I'm hearing prices of 225-275The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Is that with an 800kva transformwr or the much harder to find 1000kva?
The cost depends on your choices with respect to the transformer, enclosure, binding posts/connectors and spikes or feet.
If you go with all new parts -- including Larry's enclosure, Neutrik Speak On connectors and a Toroid Corporation (Maryland-based and "Made in America," you may be able to build one for $300 or so.
If you go withLarry's enclosure, Cardas binding posts (for example) and the Avel-Lindberg 1000VA transformer that has been the one preferred here, you're going to be over $400.
Your choice of spikes or feet can add a little (rubber feet) or spikes a lot, depending on your choice.
If you decide to go with a custom fabricated enclosure, the sky is the limit.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Just to clarify, the Avel-Lindberg 1000VA audio grade transformer is a special order only item with a minimum order of 10. The 1000VA version listed on their site is not to be used for audio.Political Correctness'.........defined
President of Club Polk -
It looks like I am going to be able to forgo this purchase until I can find a really, really good deal. For now I will just be strapping the monoblocks.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
I'd offer some sage advice, but since you didn't ask......Political Correctness'.........defined
Unless your advice is where I can get a free one, it won't help me much!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Well, the advice is free.Political Correctness'.........defined
Then lay it on me.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Do it in stages. When you have the money buy the 800VA tranny, mount it to a board and wire it up with whatever speaker cable or hook up wire you may have laying around. The Neutrik connectors are pretty cheap, but be sure to get the 4 pole version. That will at least get you the advantage of the transformer, which is a vast improvement over strapping. Down the road buy a case and better cable.Political Correctness'.........defined
That sounds like a good plan. Approximately what does the tranny run?The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
I have a note from 2013 that the Y236906 (800VA) was $117.48 plus shipping.
Another temp idea, cover the tranny with a cardboard box with 10 layers of aluminum foil covering the box. This will help deal with EMI/RF issues.Political Correctness'.........defined
When I bought my 800 v/a the price shipped was about $133 for reference.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
I ended up acquiring one if these babies from a VERY cool guy I met at this year's Carverfest. I got it installed I to my system yesterday and the difference was immediately noticeable. I don't know any of the engineering concepts behind it, so I don't know how this is possible, but it really opened up the soundstage compared to what I was getting with the cheap cable I was using and strapping the two 7t amplifiers together.
Thank you Jerry for your amazing generosity!Post edited by trav0810 onThe difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Good for you! Yep, strapping just never seems to sound right.
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
