Parasound A21 Vs JC-1 Mono blocks
acmf74
Looking into Parasound amplification.
Do both amps sound the same or do the JC-1s more sound musical?
Thanks.
Thanks.
JC 1's all day long for me.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
^^^^This
If you are looking give DSkip a holler, he's a dealer2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I'd concur with the other gents....The JC1's are on a way different level than the lower lines. They should be too given the price difference but they were built to be a flagship amp and not just an updated series.HT SYSTEM-
lsi 9's -
This question has been one of those I've been curious to answer myself.
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
To repeat, aren't we comparing new $4500 each x 2 vs one $2500 amp?
I love my A21 gotta think I'd marry a pair of JC 1 Monos if they showed up at my door..Twins.. -
A JC1 amp is capable of 135 amps peak to peak power output compared to the 60 amps per channel on an A21. It also has a 1.9kVA transformer compared to the shared 1.2kVA transformer in an A21. The internal build quality is more robust all around to accommodate the higher power output, which allows the JC1 to run up to 25 watts in pure Class A mode. This bias mode would make it sound more musical, as well as being capable of greater power output. The design philosophy and many parts are the same though, including the chassis, to save money in the product line. I am happy with an A21, but considered getting a pair of JC1s over the years as the A21 can sound a bit solid state "grainy" when pushed hard compared to higher end amps.
Thanks everyone!
