Common Ground Amp/Receiver Question
jdjohn
jdjohn Posts: 3,375
I have a pair of SDA-2Bs and several common ground power amps that I switch up with them. I have recently rescued a few receivers from my dad's garage, notably a Sansui 9090 (left an AU-999 behind til next trip) and a Rotel RX-602. I'm curious to try these receivers/amps on the SDAs without the power amps in the chain. Is this safe? I don't know if these vintage receivers/amps are common ground or not, and since they have A/B (or more) speaker connections, I'm not sure if the usual testing for continuity would even work.
Thanks for any insights.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    the 9090 is common ground, don't know about the other.
    SDA SRS 2.3TL's
    SDA 2B TL's
    pitdogg2 Posts: 27,179
    receivers by nature are common ground
  • jdjohn
    jdjohn Posts: 3,375
    Great, thanks guys. I have some fun ahead of me, then, trying the receivers alone with the SDAs, and then using them as pre's into my McCormack or other power amps.
