I broke the #1 rule
leftwinger57
in Electronics
Yep, I sure did. The #1 cardinal rule w/ electronics is don't mess w/ the wires while powered up. So guess what, when converting my speaker wire ends from bare nothing to bananas to do my single speaker real world test I shorted out a pair. Some how it arched and the Adcom blew. I was hoping and it came true that it was only an accessible rail fuse which it was. Clearly blown, you didn't need a meter or continuity tester to figure this one out. After a lot of real choice words I went to the auto parts store got my 71/2amp fuse and all is well w/ the world. I know better than this, I guess because I had so much more room that either I can get by w/o spooling down or just forgot and paid for it. It never pays off just shut it down and w/ me my Adcom comes on instantly so it's not like I'm waiting for any warm up time and I just blew it both literally and figuratively. Just slap me in the face,why don't you....
While powered down over night I took a soft foam brush for some very gentle cleaning.
Sorry I forgot to add that Adcoms of this age do not have any speaker fuse or DC protection that is readily accessible at all. If the fuse I replaced is it then those should be outboard mounted w/ a twist cap holder. Why that is I don't know but I did know this and putting an in-line fuse for speakers does not seem that hard of a thing to do. Maybe some of the more engineering types here could say why do it or why they did not but if only for cost the thing was reasonably priced when selling new. 2nd pic was of the blown fuse and it's blackened case and did not present well.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
At least it was just a fuse. Glad you got it fixed.
A few years back I broke that same rule with much worse results.
I been there - and it wasn't just a fuse! Count your lucky stars as Mom would say!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
leftwinger57 wrote: »Sorry I forgot to add that Adcoms of this age do not have any speaker fuse or DC protection that is readily accessible at all. If the fuse I replaced is it then those should be outboard mounted w/ a twist cap holder. Why that is I don't know but I did know this and putting an in-line fuse for speakers does not seem that hard of a thing to do. Maybe some of the more engineering types here could say why do it or why they did not but if only for cost the thing was reasonably priced when selling new. 2nd pic was of the blown fuse and it's blackened case and did not present well.
The rail fuses are the only protection, they don't have soft start or dc protection. One of the reasons I always liked them. That stuff if done inexpensively adds noise and is in the signal path, etc.
H9Post edited by heiney9 on"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
whew, that was lucky, Lew!
I know, it's a nuisance for quick changes, but I have to make myself shut everything down every time.I disabled signatures. -
Just be glad it was just only a fuse. Blowing out a circuit board would not be fun.
A good reminder of how dangerous being an audiophile can be.
Glad things are ok on your end.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
nooshinjohn wrote: »A good reminder of how dangerous being an audiophile can be.Glad things are ok on your end.From tragedy impending to tragedy narrowly averted...
Thanks to all for your concern and being open about blowing up your own stuff. Such a simple thing to do,I have a master switch also and all kinds of ways of shutting it down and just got lazy and paid for it. I was embarrassed to post this and then I said, this could be a cautionary tale for the newbies here not even realizing the pros make errors too. Mark, I can't even imagine messing w/ tubes being so hot and then if it takes so long for optimum use how long does it take to spool down to where it would be safe. I know there are many sizes of tubes so no direct answer here unless there is a golden rule for tubes.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Safe to do what with tubes? Rolling them, I usually wait until they are cool to touch and then swap away. Working on the innards, I'd wait quite a while since high voltages can be stored for quite sometime in a tube amp (power amp).
Same caveats apply to tubes, don't be swapping cables with the power on.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
When I shut down the Thresholds, they still play music for up to 8seconds2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
GlenDog was the one who told me to always wait a few minutes after power off the Amplifier before doing anything.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
It's not power amp related but when I was rebuilding my RTA11TLs I forgot to put the dacron back in 1 speaker. I was SOOOOOO bummed because I thought it was crossover issues. Walked into the kitchen and see the dacron on the table...D'ohJust a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Approx 30 years ago when I had a basement bedroom at my folks place . . .
I was jam'n as usual, turned down the Adcom 555-II and went to bed with the music playing softly.
Now, what are the frick'n odds that my mom would spill a glass of water off the night stand and have water trickling down into the amp?!?!
Choice words to say the least But the fuse Saved The Day!
signed,
Lucky BastageAC Regenerator PS Audio PerfectWave Power Plant 10
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
txcoastal1 wrote: »When I shut down the Thresholds, they still play music for up to 8seconds
Randy/Maine -
My tubes vary by volume level, sometimes as long as 30 seconds
Glad none of you dudes are manning any of our nuclear silo's.
Whats that plug for ?
I dunno, plug it in.
Whats that noise ?
Uh....Moscow just got toasted....oops.HT SYSTEM-
lsi 9's -
Whats that noise ?
heh -- like we'd tell you if we were...
I mean... didn't you ever wonder why some of us seem to have so much... spare time?
mhardy6647 wrote: »Glad none of you dudes are manning any of our nuclear silo's.
Whats that noise ?
I do indeed.....Lets face it, if we all knew someone like Russ was manning the buttons to nuclear holocaust, we'd be leaking a bit in our shorts.HT SYSTEM-
