SVS PB12/PB10 integration
Good evening everyone!
I recently picked up a damaged but repairable(felling confident) SVS PB10-NSD from eBay. Some of you might have seen the listing.
I know most use identical subwoofers and would be ideal. But I talked the guy down and couldn't really pass on it lol.
I talked to SVS, they said both "should work GREAT together and good find" LOL.
I asked if it will render similar results if at least a PB12-PLUS.
He said- "yes, definitely. Might not be as low but presence and quality it will. Probably a little more than a PLUS"
Both of the subs will have NSD drivers and Bash amplifiers (that's good).
The PB12 will be up front
(Between left Lsi9 and LsiC)
PB10 will be used in rear
(Right back corner if facing TV)
Have any of you used a similar setup? Good result? Or possible headache from calibrating/tuning them?
Needless to say I am very excited, I just hope I do not have issues.
Cheers!!!
Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen"
  • Also,
    Anybody know if you can purchase a 3.15amp time delay fuse locally? Lowe's, home depot, ace hardware? I don't have any radio shacks. The fuse I bought hasn't even shipped out yet. So would like one local if possible. Thanks!
    Cheers!!!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
  • quicksilvergtsquicksilvergts Posts: 276
    edited May 2016
    I just called, no go. Thanks!!
    Anyways it was a BAD gamble on my part.
    I tried most of what could. I overlooked the photo that crossover switch (enable/disable was sheered off) on the amp. Needs new amp. Driver works. Amp just turns on with zero sound.
    A costly mistake... it's been awhile though lol.
    Pretty bummed to say the least amp is $250. I might take to local electronics shop (doubt it though). With a new amp I get a 5 yr warranty lol.
    "It is, what it is."
    Cheers!!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
  • Even better, the sledge 400D from SVS is on back order LMAO. Just my luck.
    Thankfully I have my trusty PB12 to hold me over.
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
Howdy, Stranger!
