any good....
cornerstone
file sharing sites out there? i have used imesh in the past but hate the spywere.:)
rta 12c
denon
sony
yamaha
vintage pioneer
denon
sony
yamaha
vintage pioneer
Post edited by cornerstone on
Not sure about others but one thing to know when using imesh is get the program " Ad-Aware " ... it scans your comp for spyware that you computer ends up getting due to imesh and other internet affiliated things and then lets you delete it. First time I did it I had like 700 files and my comp was so damn slow. Now when I scan I find about 10 a week and my computer is so much faster.
btw ... ad-aware is free. just do a search for it (unless you have it already) -
have you tried kazaa lite? witch has no spyware:D kazaa has spyware bad :mad:
drakan -
T O N S of spyware and virus' alllllll over Kazaa and lite. I got rid of both and never looked back.
LimeWire > all as of right now. Just do the regular version, no need to pay for the upgraded one.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Ad-Aware can be found at:
www.lavasoftusa.com
just download the free version, it works greatReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
thanks for the info about kazaalite and limewire
drakan -
OUCH .... kazza in any form is bad news (as most P2P are) .
Adware is your friend and HIGHLY recommend !!! You can also set Adware to run automaticaly at boot up . First few run times it will take a while to finish , but after that it goes quite quickly when used every day .
My.02
SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
