Toe in for lsim705
Possioning my 705s is a pain as I use a Lazer and nails to open up the holes in the carpet for the spike feet and Alan key to level the speakers..
Last time I did it after upgrading the system was about 2 weeks ago and it's bugging me.
I have them toed in at a perfect V shape pointed to the mlp. Aimed them perfectly center to the middle with a Lazer and it seems too aggreasive of an angle.
Is that the correct way or should they be like pointed to the left and right ear?
Sure I could move them it just takes me a good while to do it and if I already have thrm pointed right I'd rather not move them to just move them back.
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family! :)
  • Emlyn
    Emlyn Posts: 4,735
    I have found the best positioning for 707s is toed in so that the tweeters point a couple of feet on either side of someone's ears in the center listening position.
  • eclypse
    eclypse Posts: 595
    Ok that makes sense.. I'm probably crushing the sound stage with them pointed to the very center using a Lazer dot.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • polk500
    polk500 Posts: 1,171
    Having my 705's for a year I have tried varying degrees of toe in, from 0 degrees to 30 degrees. I prefer about 5-10 degrees off axel, as I found the more aggressive 30 degrees narrowed the sound stage to much for my liking.
    But a lot depends on your room, when we rearranged / replaced the furniture in the media room, I had to increase the toe in a bit to get the sound I like from from 5 to 10 degrees.
    Cheers
  • hochpt21
    hochpt21 Posts: 5,423
    About a foot outside either ear for mine.
  • eclypse
    eclypse Posts: 595
    Thanks guys.. I'll get to re adjusting them later tonight.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    tonyb Posts: 33,072
    hochpt21 wrote: »
    Agreed, when using that V in aiming the speakers at your listening position, it's been my experience the point where the 2 lines meet should be behind you a couple feet. That way your head is inside the V, unless you have an enormous head of course. ;)
  • Mikey081057
    Mikey081057 Posts: 7,127
    I like to put my head in the V
    Garage | Polk Monitor 5B's
    msg Posts: 10,452
    Mike must wear his hair slicked back.
  • gce
    gce Posts: 2,158
    I'm offended! LOL
    Anaheim Hills CA,
  • footwedge
    footwedge Posts: 475
    tonyb wrote: »
    hochpt21 wrote: »
    Or dumbo ears. :D
  • eclypse
    eclypse Posts: 595
    Thanks again guys.. re positioned the speakers and my delicious sound is back to normal!
    I aimed them both a foot out from center.
    Can't wait to spend 3-4 hours listening to them agsin this morning.. as soon as the wife wakes up! Haha
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    msg Posts: 10,452
    What better way to wake up a wife, that's what I say!
    Note: Not responsible should you find every screwdriver in your house relocated to storage in each of your 705s' drivers.
  • eclypse
    eclypse Posts: 595
    msg wrote: »
    No way I'd attempt that! My wife loves her sleep :/
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • gce
    gce Posts: 2,158
    eclypse wrote: »
    The best way to do critical Listening is when the wife is away! ;)
    Anaheim Hills CA,
  • eclypse
    eclypse Posts: 595
    gce wrote: »
    eclypse wrote: »
    I guess I've been lucky so far as she has not complained too much about the loud music hehe. Though yes majority of my listening is when no one is home. ;)
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
