Let's Talk About Synergy
Early B.
As many can attest, audio components mate better with some than others. In order to get some more insight on this issue, let's get some feedback on the following:
1) What brand or specific set of components do you feel mate best with a particular Polk speaker? Why?
2) Do you consciously make purchasing decisions based on whether or not a particular component will mate well with your system or do you rely on the trial and error method?
3) What auxillary components (i.e., interconnects, speaker cables, etc.) appear to bring out the best in your system?
4) What was the best system you ever heard? What made it so damn good?
Thanks in advance for your contribution.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
1. I always figured with solid state that the more power the better. Changed from 45w to 100w Denon reciever and is still not enough for a pair of RT55I's
2. After doing a lot of research and hanging around here and seeing what others use........you bet "synergy means everything.
3. A few do not care for, but Monster cable smokes Home Depot or Rad Shack anyday.
4. Something I will never forget was two B&W 803's powered by maybe 200-300 watts of Mcintosh. Hard for me to describe how "FANTASTIC" that was. Those two together are what I judge others by.
..................................................Good DayDenon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
Have to preface all by saying that speakers are around 80% of the SQ equation in my book. You can screw up good ones with bad gear in front of them, but no amount of great gear can compensate for bad speakers...
I have always loved Bob Carver amps with Big Polks. They have the balls to drive them without working hard. For years it was an early Carver M-1.5t that had the honors. When it had to go back to the factory for some repairs about 4 years ago, they not only repaired it, but upgraded it with all the refinements that were incorporated in the last of the 1.5's. It was soooo much sweeter when it came back, I could not believe it was the same amp. Of course, actually it was not.
Had a similar "epiphany" when I bought my first B&K Pre about ten years ago, an unexpanded AVP2000, i.e., it was only 2 ch and I never did get it upgraded. It replaced a Yamaha C-2 pre that I thought had done nice work for a few years. Moving to the B&K was like lifting a veil off of my SRSs. No going back When I decided to go Pre-Pro, my choice was easy.
In large part I believe that both of the above improvements are owed to the SRSs SL2000 tweeters, which are generally recognized as a bright tweeter. I also learned after the B&K switch, that Yamaha gear is generally considered to be bright. And later that Carver gear was considered harsh (measure of brightness in that description as well). From my first stereo I had always been a treble booster, so I do (or did) like my music bright. I now know my SRS 1.5t C-2 combination was overdoing it.
Last years move to Sunfire was not the equal of either of the step changes I mentioned above, but some refinement was added. Especially so when I selected the amps Current output option for the SRSs tweeters. This did just a little more smoothing of the highs.
I am still searching for some sources, but love the vinyl Shure - Thorens AA Vac-in-the-Box chain to which I add a little dbx magic from time to time
I know of no way to anticipate what the results will be, other than info I gain from forums. Given the above, I try to avoid bright gear in my HT. But its all trial and error; its just not necessarily all my personal trial and error...
3) What auxiliary components (i.e., interconnects, speaker cables, etc.) appear to bring out the best in your system?
I am one of those doubting Thomases when it comes to wire. And I remain so even after my Cable Demo time (courtesy of this Club and the Demos mastermind, doro), as it was so fraught with issues that I never did conclude my tests and sent the items on before I killed the efforts momentum entirely.
That said I did once invest in a pair of Tara Labs ICs that I enjoyed for a few years. More recently I moved to Signal Cables Balanced XLR ICs for my front soundstage, and am pleased. But again, nothing earth shattering occurred with either wire upgrade.
I have had my jaw dropped twice in a listening experience, and have been startled a couple more times.
Jaw drop #1 was my first SDA experience. A local shop where I went to buy my first Carver amp was running the SRSs in their premier listening room. I could not believe the width of the soundstage these beasts threw, and threw with power I had not felt before. Demo material was DSOTM (of course) and Flim and the BBs Tricycle. Rest of the system as best I can recall was Carver, Carver and more Carver. I bought the Carver, but never forgot the SRSs and nailed a used Pair a couple years later.
Magnepan 1.6s brought on jaw drop #2. The precision and depth of imaging on Dave Brubecks Blue Rondo was astounding. They were running off of B&K 2 ch separates. A very sweet rig complemented by a Vanderstein sub for more genres more demanding than a Jazz quartet. As a result I picked up my used Maggie 1.5s last year on ebay.
Startles are too numerous to get into (I wouldnt want this post to get too long
), but a couple occurred at TxPFII at RuSsMans hacienda, and I am looking forward to more on the 8th, 9th and 10th at Polktoberfest
More later,
Tour...
Vox Copuli
