SRS Interconnect Cable
Hello, I'm looking for a replacement 2 blade interconnect cable for my SRS. I got one off of Ebay but I am disappointed in the quality. Does Polk still make them?
Thanks,
Tim
    F1nut Posts: 51,778
    edited April 2016
    Yes, they do. However, it may not be different from the one you purchased. Polk makes them up these days as a courtesy. They do not have the molded on ends like the originals. A lot of us here swap out the stock SDA socket for an air tight, 4 pole Neutrik socket, then make a new SDA cable using high quality speaker cable with a matching 4 pole male Neutrik plug.
  • timtam77
    timtam77 Posts: 2
    Thanks. I may want to change my set up.
