Has anyone used Aspen Amplifiers from Australia?
Here is the web page:
http://aksaonline.com/products/products_NAKSA100.html
Its called the Naksa 100 Power Amplifier that you can build as a kit - you purchase the board fully assembled, then you source the power supply, binding posts, input RCA Jacks, and the AC filtering modules (I believe, or it may be built in on the board), and assemble it in the case.
This product may have been superseded by another model. If anyone has tried any of their models, what are your thoughts?
Thanks!!!
Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart.
    Never heard of them. A class a/b design at 100 watts per/180 at 4 ohm....wouldn't match it up with hard to drive speakers though. Whats the end cost after sourcing everything else to complete ?
