Pioneer MCACC Effect on LFE
Does the MCACC in my Pioneer SC-07 process the sound going to the LFE output under the low frequency crossover (mine is set for 80hz)? If so, is there a way to disconnect the MCACC for LFE only? Can't find any reference to this in the manual.
My concern is that if the MCACC is processing the LFE, and my SMS-1 is processing the LFE, there may be overlapping processing that is conflicting.....
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • mikeyb128
    mikeyb128 Posts: 2,885
    I owned an sc65, MCACC did not eq the sub. It would set distance for delay and volume. I ran a separate eq for my subs (an antimode) then re-ran MCACC after the antimode To adjust for any delays with the antimode in place.
    I would do the same with your sms-1
    2 channel:
    Theater:
