Parasound P3
ROHfan
ROHfan Posts: 1,014
edited April 2016 in Electronics
I've been looking around for the P5 but it's pretty scarce. I have, however, found a few P3's on ebay that look to be in good shape. What would be the benefit of the P5 over the P3? Should I hold out for it or is the P3 a good transitional pre?
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    tonyb Posts: 33,072
    Transitional ? As compared to what ?
    The P5 is a better pre in every way, save your coin, one will pop up.
    msg Posts: 10,452
    edited April 2016
    Onboard DAC, sub out with crossover controls, and HT Bypass are the main standouts.
    The P3 could be a good transitional pre if you really want Parasound, need one now, don't need any of the above, and can't wait for a P5 to show up.
    I was in the same boat as you. I started with the 2100, considered the P3, but decided to hold off, and ended up waiting about a year and a half for a P5. I just used my other stuff in the meantime, and looking back I'm glad I waited.
    If not, you might also consider the Model 2100 in the meantime? If you need these features, it's got HT Bypass and sub out, but crossover control is limited. It's got low-pass, but hi-pass is limited at 80Hz.
    Not sure how the sound quality compares between the three, though. I feel like the 2100 is a little edgier than the P5, fwiw. I'd say hold out if you really have your heart set on the P5.
    Parasound Halo P3
    Parasound Halo P5
    Parasound Model 2100
  • ROHfan
    ROHfan Posts: 1,014
    la2vegas wrote: »
    You could pick up a P3 cheap and unload it when you finally find a P5. No affiliation. http://neworleans.craigslist.org/ele/5456828684.html Just a thought.
    A little far from me, but thanks. I get my Energy RC70s this week so I'll see how it sounds just using the Teac DAC pre first.
  • Upstatemax
    Upstatemax Posts: 2,736
    I love the flexibility of my P5. I thought that I would never use half the options, but I have since used all of them...
    the sound quality of the P5 is awesome for the $$ and it is a versatile unit.
    I say hold out for the P5.
  • Jaybeez
    Jaybeez Posts: 748
    The P5 is on my short list as well. I'm holding out until I find one. Nothing else looks remotely close to meeting me needs for anywhere near the price.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • ROHfan
    ROHfan Posts: 1,014
    I may wind up getting the 2100. I just got my new RC70s hooked up and they sound wonderful, but I'm using the volume control in my Teac DAC. Not sure if that's an ideal setup. The 2100 might round that out rather nicely, and I definitely need the sub integration and HT bypass.
    tonyb Posts: 33,072
    P5 in the FM right now for 650 bones.....run.
