Adding an amp to my reciever
I have a pioneer SC 1228 receiver with two rtia7s for my front speakers. I feel like the receiver does not have enough power to properly run them. I am thinking about getting a stereo amplifier to go through my preouts. Just wondering derived g if anyone knows if I should be ok with what I have or if the additional power would be beneficial
  • Also wondering what a good amp for the rtia7s would be
    F1nut Posts: 51,787
    Is your question in reference to HT or 2 channel music?
  • chumlie
    chumlie Posts: 8,658
    Yes it would be beneficial. Parasound is good with A7
  • I don't know what paramount is
    F1nut Posts: 51,787
    edited April 2016
    If your system is 2 channel only using an AVR as the pre amp isn't the best idea. A dedicated 2 channel pre amp will have better sound. Anyway. Chumlie suggested a Parasound power amp, which is a good suggestion. It's on the warmer side and will help tame those tweeters a bit.
    tonyb Posts: 33,072
    Look for a used Parasound HCA 1200 OR 1500. Usually around 400 bucks. They make excellent first amps and sound great with RTI's, and.....won't break the bank.
  • gp4jesus
    gp4jesus Posts: 2,019
    A Parasound HCA-1000 will "get 'er done" if you don't need to lift your place off the ground.
    *all connected w/Premiere ICs
