Kendeil Audio Grade Power Supply Capacitors
These are audio grade (K05) Kendeil power supply caps made in Italy, which are considered by many to be the equal of Mundorf M-Lytics. In other words, excellent. They are not commonly found in North America and in fact, I had to special order them. Since they have a minimum order I have extras and thought someone might be interested.
These are brand new audio grade, 105 degree, 5000 hour rated, +/- 20% tolerance, but all test at - 11% or 12% tolerance. Very respectable. The 6800uF are the 100V version, which are hard to find in an audio grade cap and the reason I ordered them.
I have the following available (I paid double)
(8) Kendeil K05 ~ 6800uF 100V (35mm x 50mm) ~ $10.00 each.
(4) Kendeil K05 ~ 1000uF 100V (25mm x 30mm) ~ $5.00 each.
Shipping ~ as reasonable as possible.
Payment ~ PayPal (+3%) or check, if I know you.
    pitdogg2 Posts: 27,197
    edited April 2016
    Silly question.. Through hole or snap in?
    Never mind looking at the size I think I answered my own question.
    F1nut Posts: 51,917
    Both values are snap in, 10mm spacing.
    nooshinjohn Posts: 25,973
    how are they working for you sir? I think they are doing a great job for me in my tube amps. Bob felt they had more speed on the bottom end than his amps of that time.
    F1nut Posts: 51,917
    I just got them and haven't had time to install. I based my sound excellent comment on your experience as well as other users reviews.
