Monitor 10a crossover rebuild kit parts list?
cruciform
Hi All,
I have a set of monitor 10a's that need the crossovers rebuilt. (one of the tweeters isn;'t working, and it the tweeter itself tested out fine.) I'm not too versed on various types of capacitors, etc, but I am good with a soldering gun. I've done some research, but most of it is Greek to me, so is there any chance of obtaining a list of the components needed, specifications, name brands, etc? I'd like to upgrade to more modern components while I'm at it.
thanks for any and all help- I've had these monitors since college, and I'm 45 now.. they've served me well, and deserve some care.
does yours have fuses? if so clean the contacts for the fuse real good and check the fuse. As for a parts list it is best to look to see what was put in yours and copy the values on hand then shop for some film caps. Many here have used Sonicaps or Clarity caps and they are well respected here
