What the DAC!? help me choose
stangman67
stangman67 Posts: 2,329
edited April 2016 in Electronics
Hey guys,
Ive been slowly piecing together a modest 2 channel setup for when i return from deployment. So far i have purchased speakers (lsim703s), integrated amp (Teac Ai2000) and a bluesound node 2 for my digital source. I am now in search of a dac to fully take advantage of the rest of my gear. I have read the onboard dac on the node 2 is decent but not great. I am looking for a dac for 500 dollars or under, not that i cant spend more but a 1000 or 1500 dac kind of kills the 2 channel system on a midfi price level.
So ive done my fairshare of research and i narrowed down to a few choices, i was dead set on a Schiit bifrost until i read some things on this forum a few years back that make me second guess that choice. Other dacs ive looked at are a used ps audio direct link 3, peachtree dac itx, cambrige dac magic, and a host of others. Still i am leaning towards the bifrost. There are tons of threads on this but everyone always has something negative to say about every product, and i respect the opinions of people here, so if you had 500 to spend on a dac, what would you buy?
One more thing, I don't consider myself an audiophile, I love music but I don't need it to be reproduced perfectly, I just want it to sound good if that makes sense. I won't worry if the sound isn't tonally perfect, or missing a bit of detail etc. I just good musical sound.
Thanks,
zach
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I have a chord Gem dac that may fit your bill, no lack of detail going on but its a 96 via usb so its a technical drawback.It does have bluetooth if your running music from your phone, I would let that go for $450 plus fees tgb9gmcnzk6i.jpg
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited April 2016
    I don't like the lsmi 703's full range for 2 channel listening.
    (In my best @F1nut)
  • stangman67
    Thanks, but the 703's are what I bought and I doubt I'll be disappointed at the 750 dollar/pair price point. If after set up, I feel the setup needs a sub, I will add one.
    Pfb, thanks. Looks like a quality unit but the lack of toslink is a turn off for me.
  • [Deleted User]
    You don't like the DAC in the bluenote?
    I assume you want a DAC for better resolution.
    I would consider a pre with a built in Xover and build
    and 2.1 or 2.2 system. When you run the 703's full
    out you lose lower end definition and aaah, data.
    They get mushy under 50hz and it effects the sound ABOVE
    50hz.
    I haven't found a DAC w/ a Xover in your price range...
  • stangman67
    Haven't heard any of it yet. All waiting in boxes at home. I'm new to this integrated amp thing, I'm thinking this whole time, oh I'll just crossover the speakers and add a sub. Whoops, not so easy with an integrated. Well I will see how it all works out. Again, I'm not looking for perfect sound, just something fun to listen to. And I think the 703's will fit that purpose nicely
  • stangman67
    Getting a little off topic. If the 703's are really that bad full range then they can move into the ht and the lsi15's can move to the 2 channel rig. I want to keep the setup relatively simple, hence integrated amp, and a digital media player.
  • [Deleted User]
    Oh, I see. hmmm. I like the pieces you have picked so far.
    Well, I think you are going to LOVE the 703's. I do.
    I listen to them every chance I get.
    Maybe wait on the DAC? Lose the stock chords on the
    bluenote and go from there?
    Have fun and report back when you get a chance.
  • stangman67
    Certainly waiting on a dac is probably the better option. I'm just sitting here on a ship and audio research is about the only thing keeping me sane lol. I'll be using quality interconnects, speaker wires for sure.
    tonyb Posts: 33,072
    stangman67 wrote: »
    Use the dac on the Node first and see how it sounds to you. Then come back and tell us what you don't like about the sound and we can better steer you in the right direction.
    Personally, the Bitfrost would not be on my list, but that's just my preference.
  • Jaybeez
    Jaybeez Posts: 748
    I got back into 2 channel fairly recently and held off on the DAC until I was pretty sure it would make a difference.
    I just pulled the trigger on an excellent used Bifrost, with Uber and USB upgrades.
    I listen to vinyl and CDs but most of my stuff is electronic, so wanted something to tame the digital beast.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • stangman67
    Thanks again for all the input,
    Skip, The IHI music system looks very intriguing but I'd like to keep what I have already bought. I bought the TEAC at a deep discount and have heard nothing negative about it. The price/performance of the Teac should be very very good at the price I paid.
    Jaybeez, interested to hear your thoughts of the Bifrost, it seems to be quite polarizing. People either think its the best value out there or way too "detailed" and bright. I hate bright so maybe the Bifrost just isn't for me.
  • Nightfall
    Nightfall Posts: 10,084
    For $600 you can get a Marantz DAC that even does DSD with both digital inputs and USB. The headphone amp is icing on the cake.
    http://www.accessories4less.com/make-a-store/item/marhddac1/marantz-hd-dac1-headphone-amplifier-with-dac-mode/1.html
    afterburnt wrote: »
    Village Idiot of Club Polk
  • stangman67
    I'll take a look, initial observations look good and it's 499 right now, so right about what I am looking to spend. Thanks!
  • Nightfall
    The HDACC up-samples all low res music sources (mp3, wav files, vinyl, tape too!)
    Since when is WAV, vinyl, or R2R low res?
    Looks like an awesome DAC Skip, I think that's the first DAC I've ever seen with HDMI.
    afterburnt wrote: »
  • Mikey081057
    Mikey081057 Posts: 7,127
    Find yourself a used Marantz SA8004 SACD has a nice dac and SACD player..
    Garage | Polk Monitor 5B's
  • Irrenhaus
    Irrenhaus Posts: 1,103
    if you want to stay in the family this looks interesting.
    http://www.audiolab.com/TEAC_AI_301DA_Bluetooth_USB_DAC_Amplifier_p/teaai301da.htm
    I have the UD-301 and love it. Great price at $399.00 and will do DSD.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    txcoastal1 Posts: 13,513
    FYI
    Teac is no slouch in technology as they are the same company as Esoteric
    F1nut Posts: 51,793
    stangman67 wrote: »
    Get a REL sub.
  • stangman67
    I have read great things about newer Teac stuff, hence why I went with their distinction line of integrated amps. Esoteric engineers were involved in the design
    tonyb Posts: 33,072
    stangman67 wrote: »
    Maybe so, but anyone who thinks they are getting anywhere close to an Esoteric in sound or build quality for 400 bucks is fooling themselves.
    That said, I see nothing wrong with teac stuff, better sounding than a lot of similar priced products out there. Dacs anyway, integrateds I've hadn't so far been able to get an ear on any Teac's.
  • stangman67
    Yea I doubt the lower end teac has anything to do with Esoteric, unfortunately the distinction line was discontinued, it didn't seem to be a popular line in the USA but the ones that have had them have loved them.
  • ROHfan
    ROHfan Posts: 1,014
    stangman67 wrote: »
    I get mine (UD-301) tonight. Bought it based on excellent reviews.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • kharp1
    kharp1 Posts: 3,453
    I just purchased a UD-301 to have as a "portable" type system. For the money I couldn't pass it up. Hopefully it's a decent piece.
  • Jaybeez
    Jaybeez Posts: 748
    edited April 2016
    stangman67 wrote: »
    stangman67 wrote: »
    I'm really digging the Bifrost. I just A/B'd a CD (Eagles "When Hell Freezes Over") run through the Bifrost vs. straight from my CD player (Marantz CD5004). The Bifrost is way more detailed, with tighter bass and clear, neutral midrange. "Hotel California" sounded significantly better on the Bifrost.
    I don't find it at all bright, but am playing it through a Yamaha Integrated in Pure Direct mode and Ascend Sierra 2's, both ensure a pretty neutral presentation.
    WiiM Mini
