Ahhhh cr@p man, I just woke up on the floor ontop of my headphones and snapped em!!
I will post pics later, lets hope there is a fix or its an expensive piece of garbage.
  • mrbiron
    mrbiron Posts: 5,721
    i love you.........honestly. :trollface:
  • Willow
    Willow Posts: 11,234
    Are you sure they weren't shipped to you that way and you just realized it now?
    tonyb Posts: 33,072
    What you need pal, is to move. Why?
    Because you always have this black cloud over you where your at. Move to the sunshine state or somethin'. :)
  • Emlyn
    Emlyn Posts: 4,735
    pitdogg2 Posts: 27,078
    put the whiskey away:)
    billbillw Posts: 7,594
    Hands off the HiFi when binge drinking.
    nooshinjohn Posts: 25,932
    ***YAWN***
    mhardy6647 Posts: 35,056
    Emlyn wrote: »
    Duct tape.
    This.
    and/or Crazy Glue.
  • DaveHo
    DaveHo Posts: 3,583
    And away we go!
  • quickr1
    quickr1 Posts: 414
    heiney9 Posts: 25,449
    Be sure to use Audio grade glue, or you might alter the sound.
  • sucks2beme
    sucks2beme Posts: 5,686
    Post the picture already. Inquiring minds want to see!!!
  • Moose68Bash
    Moose68Bash Posts: 3,843
    @polkfarmboy,
    You are the only human being I've ever come across who is justifiably worthy of the descriptor: "An accident waiting to happen!"
    You have my sympathy.
  • 11tsteve
    11tsteve Posts: 1,166
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    Get a higher model V-Moda and see if you can BREAK them! lol
    msg Posts: 10,452
    edited March 2016
  • polkfarmboy
    polkfarmboy Posts: 5,703
    cnh wrote: »
    These were not super high end but they are the first pair of decent headphones I have purchased. I loved( past tense :'(. ) using them for video games and movies more than music. ruiuutebr80s.jpg
    msg Posts: 10,452
    ouch.
    this is one thing that really annoys me about modern merchandise - so much stuff with a cost point that simply doesn't match its quality. I'm starting to feel like an old man as I think to myself more and more often, they just don't make things like they used to...
    yeah, I'd be trying to repair that, though given the tension, not sure how successful you might expect that to be.
  • lightman1
    lightman1 Posts: 10,796
    Roofing staples....right into the noggin. They will never shift.
  • voltz
    voltz Posts: 5,384
    edited March 2016
    Don't give him super glue :( he will glue them to his face or head by mistake.
    msg Posts: 10,452
    or bust off the other one and make a suggestive bikini that answers for itself
    "oh, those are nice, may I?"
    edited March 2016
    msg wrote: »
    ouch.
    I tried to fix a broken pair of "Rock & Roll Hall of Fame" R/S headphones for my son, years and years ago now, and ran into the same problem (i.e., stress and molded plastic are pretty uncooperative).
    voltz wrote: »
    I once read an interview with the phenomenal Canadian songwriter/singer/guitarist Bruce Cockburn, in which he mentioned that, as a guitarist, he would often repair and reinforce his fingernails with superglue... but he wryly admonished that doing so after drinking was a recipe for disaster :-P
    EDIT: FWIW , from "The Cockburn Project"
    http://cockburnproject.net/
    Bruce never uses a plectrum or fingerpicks and plays very hard so he treats his fingernails regularly with Crazy Glue the application of which he warns with a voice of experience should "not be done when you're drunk."
    --from an Interview by James Jensen at Sunset Sound, Los Angeles, circa Spring 1993.
    2 November 1981 -
    Some odd & ends - comments that defy classification
    Q: A real practical question: playing fingerstyle, slamming the guitar, how do you keep your nails? The Pete Townsend school of manicure...
    BC: Well put... I coat them with Crazy Glue. You have to be very careful... you've got to make sure you don't get it anywhere but where you want to put it... when I first started doing it, I glued my fingers together...
    Q: It doesn't have any bad effects or anything?
    BC: It appears not to... I'm a little hesitant to recommend it to people...It does work, it makes them really strong. You can see this crusty little layer on here... it doesn't actually soak into the nails, but it really keeps them hard.
  • sucks2beme
    If you are drinking enough to cause all this mayhem all the time,
    you may want to consider cutting your liver some slack.
    gudnoyez Posts: 8,166
    Wrap them in exotic wood and sell them to someone in Mexico, lighting might strike twice and you will get your money back when they are held up at the Border.
  • vmaxer
    vmaxer Posts: 5,120
    gudnoyez wrote: »
    Too funny!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • polkfarmboy
    gudnoyez wrote: »
    A deviously smart cunning plans brews! More than likely some one will stuff the box with blacktar heroin and I spend the rest of my days baking cookies for the inmates of a mexican prison.
  • ken brydson
    ken brydson Posts: 9,005
    gudnoyez wrote: »
    Thanks for giving us an upside....
    tonyb Posts: 33,072
    Baking cookies ??
    Um....in a Mexican prison pal, you'll BE the cookie. ;)
  • halo71
    halo71 Posts: 4,635
    --Gary--
