Phono Preamp Suggestions?
I'm still wondering who got #420? Lol
that person is probably gonna be a while leaving a review anywhereI disabled signatures.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I noticed a light twittery/thumpity sound from my right channel at idle. Haven't had time to investigate.
Not sure if it's the unit.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
yes, great description - that's what I experienced as well. it went away after it was on for a while.I disabled signatures.
Okay, so the Budgie is a relatively light weight unit.
Was thinking about this last night and now inspired to action by soundfreak's question - any thoughts on benefits/drawbacks to Dynamatting the lower chassis of this or any other phono preamp?I disabled signatures. -
This sounds tube related. Next time it's off, swap R and L tube then power it up to hear if it moves.
Wowsa! It's a Budgie run! lol
I've never seen/heard Dynamat hurt anything unless you block air vents.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »
I will try that, thank you.
I got my rubber band replaced and that took care of the other issue, but the pattering is still there in the right channel. I can only hear it if my ear is to the speaker.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
good tips all, and all currently neglected.
Quick question - do you guys notice that the input signal strength from the phono pre to the preamp/receiver seems lower that of digital inputs signal strength? Seems like it requires more volume knob with phono than with digital sources.
That's pretty typical. As long as it doesn't require a TON of extra volume knob you are just fine.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Interesting on the tubes.SCompRacer wrote: »This sounds tube related. Next time it's off, swap R and L tube then power it up to hear if it moves.
Thanks on the Dynamat. I might give that a shot. was wondering whether the lining would cause any shielding/reflection type issues.
Is it a common mod to vibration damp phono preamp chassis?
Paul, how much time have you got on the unit now? I'll check tonight to see if mine does it again during warm-up, and whether it stops.I got my rubber band replaced and that took care of the other issue, but the pattering is still there in the right channel. I can only hear it if my ear is to the speaker.
what's a rubber band? the belt?
cool, thanks.That's pretty typical. As long as it doesn't require a TON of extra volume knob you are just fine.I disabled signatures. -
Probably around 8 hours. I've played 5 records tonight and I listen to the speaker each time. It's doing that pattering thing every other time I check.
My TT has basically a thick rubber band that decouples the motor from the plinth. When it wears out, the spindle leans towards the platter and the belt rubs against the top of the spindle groove. Makes a bad noise and wears on the belt and the motor.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
weird. did you get a chance to swap the tubes yet like Rich said to see if it travels? I was a little concerned about mine when I first got it, as the box was a little molested, and then when it made that noise after hooking it up, I thought, oh no, but then it went away. I just got home and started everything, and it's still quiet, so yours might clean up too. good thing is 2yr warranty, and Shannon seems like a straight up dude, so pretty sure he'll sort you out one way or another. just a bummer though. wonder if it'll tighten up after the 24hrs?
ah, I see.Post edited by msg onI disabled signatures. -
Switched the tubes and noise still out of the right channel.
I'll have to check my cabling next.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Just purchased a NOS pair of Amperex Bugle Boy 6DJ8 Holland. Got these based on Shannon's recommendation. Hopefully will be here by the end of the week. I'll let you all know how they sound.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Nice... Where did you getem? I am having a set of cables sent for phono to phono pre and phono pre to pre... Did you ever figure out the noise?
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »Nice... Where did you getem? I am having a set of cables sent for phono to phono pre and phono pre to pre... Did you ever figure out the noise?
eBay. Seemed like a trusted seller, but we'll see. I keep forgetting to check. It's not doing it right now, though.
Added weight, air and presence. Worth $50 for sure. Stock tubes aren't 'bad' in comparison, but definitely a noticeable increase in SQ.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Upgraded the cables with a nice pair of grounded VERY quiet cables.
Upgraded my tubes with a matched pair of 70's NOS Gold Pin Tesla E88cc's.
Super quiet. Very black background. I will listen tonite and get some feel for them.
Budgie is sounding very fine...My New Year's resolution is 3840 × 2160
Mikey081057 wrote: »Upgraded the cables with a nice pair of grounded VERY quiet cables.
What cables?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Niiice - you've been busy
yes, curious about the cables and any other info on the tubes (source, etc.)?I disabled signatures. -
Got the cables from a guy on the bay who makes them..
Tubes from Tubmonger...He is a very reliable source. The real Tesla's are very nice tubes for a pre.
These tubes are a big upgrade to the Budgie...Listening to some of my favorite Jazz albums... Some Monk, Mingus, Brubeck and feel like I am at Jazz Club in NYC... The sound is so organic and realistic... noise floor is lowered ...cymbals are bright ... the piano has got the voice of angels... I might have gone a tad overkill on this pair of tubes ($80 pair) but the Tesla's never seem to disappoint. All around deeper soundstage. Acoustic instruments seem to make these shine... Not broken in yet but so far very rich and feel these add to a winning combo for my rig/ears. The tweets in the Ushers are incredible.My New Year's resolution is 3840 × 2160
wow, sounds like a great upgrade. $80/pr doesn't sound unreasonable for all you're reporting. did this come from the tubes, or the tubes/cables combination?
would you mind sharing the cable seller info and specifics? curious to read up some on the cables.
Monk... is that The Loneliest Monk?I disabled signatures. -
yes Thelonius....:) pure genius..
The tubes seem to bring it... but when i think about it...the cables cost more than tubes...i've had the cables hooked up for a few weeks while i was researching the tubes. the cables lowered the noise floor some... but now the tubes and cables have made it so you have to have your ear to speaker with the volume relatively high to hear any noise. Quietest vinyl rig I have ever had/heard...My New Year's resolution is 3840 × 2160
Here's the cable guy.... nice quality... nice materials...They are quiet..
http://www.ebay.com/itm/191538892148?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I got 2' and 5' pairs.My New Year's resolution is 3840 × 2160
Ah, silver, very nice, and fantastic knowledgeshare on the upgrades.
Cables description seems to indicate very nice quality. Mentions military grade - Black Cat Cable is the only other brand I've seen so far that uses that descriptor. Also curious about the multiple ground wires?
So did you go with these for the whole phono signal path, hence the 2pr?
Thelonius - there was a program on HBO called Hello Ladies with Stephen Merchant. Pretty funny, though cringey at times. His airheaded roommate was pretending to be a jazz fan and listed The Loneliest Monk as one of her favorites. I knew immediately that she really meant Felonious Monk.I disabled signatures. -
Yes from phono to phonopre and from phono pre to p5 line level....
I was just doing some reading over at Vista Audio, at Skip's mention of the Spark Integrated, and I noticed that they offer a phono preamp as well. Given the surprisingly pleasing experience with the little Dayens Ampino audition, and that Vista is designed by the same guy who designs Dayens, I'm a bit curious about this piece. Similar pricing to other phono preamps; $300
http://www.vista-audio.com/products/phono-1mkII/index.htm
Tesla's mostly broken in now ... prolly 60 hours on them... much better than the EH that came with the Budgie.... Tesla's are known being very musical pre tubes and these are no exception fuhdamsho.My New Year's resolution is 3840 × 2160
