Will Polk Audio RTI A1 speakers work with my home amplifier?
xXFEDERICOXx
xXFEDERICOXx Posts: 1
edited March 2016 in Speakers
Hi,
I was searching for speakers to upgrade my home theatre system VSX-415 (http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/218219113VSX515OperatingInstructions.pdf)
Specs:
I does say that it have 130W output for each channel but i have no idea if it will be compatible.
Thanks in advance, and sorry for my english :)
    F1nut Posts: 51,782
    They will be fine.
  • polkfan38
    polkfan38 Posts: 360
    Yes.
    Things are more like they are now than they ever will be!
  • polkfan38
    With two channels driven, it might be 130 watts. I have not seen a bench test but I would bet with all channels driven, its more like 50 or 60 wpc. Still adequate with the RTi1s unless you like to rattle the dishes.
