Does anyone use the lead weights made for drapes?
I want to get a bunch to place a bunch of them on top of components to at least deaden the cases of maybe everything. Has anyone thought of this our used them?
  • afterburnt
    afterburnt Posts: 7,892
    edited March 2016
    They are the kind of things that you can get from "Michales or some place like that. you could probbly drop em inside as well like the pading dynamat like a lot of you use. I think they are littlle flat slabs of lead in muslin bags.
  • mikeyb128
    mikeyb128 Posts: 2,885
    How about trying it? I love trying cheap tweaks. I haven't tried weights on my gear, I usually try to have good isolation first. But isolation doesn't help with air born vibration.
    2 channel:
    Theater:
  • aprazer402
    aprazer402 Posts: 3,400
    One of these ought to do the trick, Bob's your uncle! :)ivkt94d6dn7b.jpg
  • afterburnt
    edited March 2016
    I am gonna try these to dampen the sheet metal on my Yamaha. If it does nothing at least I will have more lead in my environment.
    http://smile.amazon.com/gp/product/B004DK6IVI?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A7OWZNGK2TTDP
  • At .05 ounces each are they enough mass to make any difference? I just weighed a 2014 penny at .08.
    Lead fishing weights would be a better buy. If you want 50 pounds or more go to a bullet casting site and check the classifieds. I loaded up a few years back so am not sure what current prices might be. My last purchase was 120 pounds delivered to my door for $140.00. One pound ingots cast from salvage wheel weights. Pure lead wheel weights were starting to dry up so have no idea what current prices might be. If you are only looking for a few pounds hit me up.
    If you have no plans to use the lead for casting the metalurgy would not matter.
  • motorhead43026
    motorhead43026 Posts: 4,017
    I use rubberized dumbbell weights with 3M bumpons. One 2-1/2 pounder seems to be sufficient.
    – Kevin Alfred Strom
    The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm.
  • afterburnt
    I never thought of that. I have hundreds of of pounds of plates now I have a reason to pick them up
  • afterburnt
    I was looking for something rather flat and thin do you have anything like that?
  • littlewoodboats
    littlewoodboats Posts: 823
    edited March 2016
    I do not have one in front of me to measure but would guess thickness at 1/2", maybe 3/8". A little larger than a dollar bill folded in half. It will be morning before I am back to the shop to measure one. I will post an image and dimensions. I have a healthy stash of muzzleloading bullets and balls so could part with some lead.
  • afterburnt
    http://smile.amazon.com/gp/product/B005XQC9I2?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=ATVPDKIKX0DER
    These are .5 oz, does anyone think that sticking these things on with double sided tape to the bottom will do any good?
  • motorstereo
    motorstereo Posts: 2,358
    Is there any reason why you would not want to remove the cases, line them with dynamat and reinstall them? That's pretty much what the stuff is made for and more than likely a better idea than piling weight plates on your gear.
    I might agree, however....maybe we should start with the obvious question. Why ? Is there something about the sound your getting your not liking ? Your obviously wanting to get rid of something your hearing.
    pitdogg2 Posts: 27,157
    well make sure the two sided tape won't get hot enough to let go and have that lead conduct across something.....and let the magic smoke out. I'd go dynamat
  • Here are some rough measurements. The smaller ingots measure 3" x 2" x 1/2" and weigh 13 1/8 ounces. The bigger measure 3 1/8 x 2 9/16 x 7/8 and weigh 2 lbs 2 3/4 ounces.
  • afterburnt
    tonyb wrote: »
    Actually tony, I don't know that I am hearing anything but with some of my gear the sheet metal vibrates like crazy.
    @motorstereo I am not opening anything up, I was thinking of stick those weights to the bottoms or sides on the outside. Those big Ingots will go on the tops.
  • Placing weights on top of gear is not a new idea. Mapleshades has a selection of weights they refer to as HeavyHat weight sets.
    http://shop.mapleshadestore.com/HeavyHat-Brass-Weight-Set/productinfo/HEAVYHAT-SET/
    It seems the idea is the weights used on top of a piece will add mass and therefore dampen vibration. I put one on each top corner of my Outlaw M-975. I have no idea what if any sonic benefit there might be but there is a noticeable difference when tapping on the top of the case. Tapping on the case gave off a hollow ring that is not there with a weight on each corner. The few images I am finding show the weights one each on the back corners and one in the middle up front.
    Sticking with my M-975 as an example I would not place any weight in the middle of the case due to deflection.
    I hear the difference when I put weights on top of my Monitor 7's but doubt the rest of my system is capable of the resolution necessary for something like weights to make a noticeable difference. Dampening a resonant frequency vibration through the housing of equipment sounds like a good idea. Dynamat inside the enclosure is common but is not always practical due to space restrictions.
    With a pink noise generator and RTA it would be easy enough to see if there is a measurable difference.
  • zingo
    zingo Posts: 11,258
    I have not used weights on top before, but any rattle has disappeared previously by applying Dynamat (or similar) to all the interior panels of the sheet metal case. I saw you mention you didn't want to open them up, but it does work very well, and looks stock as well.
    We Italians use bodies as weights, wrapped in drapes....preferably of the non-living nature. Well, they can be living, but usually with a cinder block and rope attached to their ankles. :)
  • motorhead43026
    I added external weight to my amp and preamp to deaden the ringing cases. My equipment is new and have anti tampering seals on them. Opening these up and adding dynamat would void the warranty. Once the warranty expires I will do the dynamat.
  • littlewoodboats
    edited March 2016
    zingo wrote: »
    What gear have you done? I can see doing the OPPO and have the dynamat ready the next time it comes out of the cabinet. The worst offender for case vibration in my system is the Outlaw pre/pro and I am not sure trying dynamat in there is a good idea. Do you dynamat the case of gear that generates heat?
    I can see the benefit to doing a disk player but would you do a pre amp?
    tonyb wrote: »
    I would think the bodies would ooze over time creating issues that would outweigh any short term sonic benefit.
