WTB: pair of f/x300i speakers
craigm
I'm looking for a pair of f/x300i surround speakers to match my rt55i fronts and cs400i center. Anyone know of a way to find some of these.
Post edited by craigm on
They are on ebay quite often, I got my white ones a few months ago from there for $190. Also I dont think they are the exact match for your setup(I have that same setup also), I believe the 500's are the match since they have the same tweeter. I would have gotten those but couldnt find any.
Your right the 500i probably is the better match, but they are to big for where I need to hang them. I'm sure the 300i would work just fine. I'll keep watching Ebay.
Thanks -
FS fx/300i
fx300i will work fine, they have the same tweeter as the 55i and 400i.
F/X300i have silk dome tweeters..
55i's and CS400i have tri lams
but as surrounds.. they match close enough. that you would be hard pressed to hear a difference.. i can't and i have tri lams in front.. and silk domes for surrounds.PolkFest 2012, who's going>?
I found this set on ebay tonight (no affil). Didn't know if you had seen them.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14996&item=5722726744&rd=1Tschüss
Zach
