Carver M-200t Magnetic Field Power Amplifier
pongshi
More spring cleaning...Carver M-200t Magnetic Field Power Amplifier in excellent working order. It has a few scratches on the top but works very well. 175.00 and free shipping to U.S. only. Specs are:
8-ohm FTC rated power per channel 120W
4-ohm FTC rated power per channel 200W
Bridged mono power 350W
4/8-ohm FTC rated THD 0.15%
IM Distortion 0.15% SMPTE
Input Impedance (Line) 100k ohms
Rated full power bandwidth +0, -3db 1Hz to 100kHz
S/N-IHF A-Weighted,dB >100dB IHF A-Weighted
Slew Rate >100
Dimensions (HxWxD inches) 2.55"H, 17.32"W, 9.20"D
Display: Power/Protection LED
Protection: Short circuit, Voice coil temperature trip, Clipping, Thermal shutdown, DC offset
I will be putting this on Ebay on Thursday, March 10th unless a Polkie wants it. Sorry, but I am trying to move stuff pretty quickly due to space issues.
Living Room
Parasound Model 2250v2 amplifier
Parasound P5 preamp
Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
Schiit Mani Phono Preamp for Turntable 2
Oppo UDP-205 CD/SACD USB and FLAC duties
Technics RS-1500US reel to reel
Polk SDA SRS (2nd Gen) fully modded
Parasound P5 preamp
Due to no CP takers. The Carver amp is on ebay until Sunday, 20 Mar 2016 at 99.99 starting bid and there is not a thing wrong with it. The new dimension shipping by Fedex and UPS is making it a lot more expensive to ship. The amp is available to a Polkie until someone bids on Ebay.
ThanksLiving Room
Parasound P5 preamp
Polk SDA SRS (2nd Gen) fully modded -
what are you thinking for the Parasound?
If I sold the parasound P5, I wouldn't be thinking
Living Room
Parasound P5 preamp
