External Amp for FXiA6
jj1127
jj1127 Posts: 5
Hi,
I am buying an Emotiva XPA-5 amp which will provide 200W @ 8 ohm per channel. I have CSiA6, RTiA5, and FXiA6 speakers. All speakers except the FXiA6 will support the 200W, but the FXiA6 says recommended power of 150W. Is it going to hurt the speakers if they are provided 200W?
Thanks in advance.
Best Answer
Answers
  • jj1127
    jj1127 Posts: 5
    Perfect. Thanks for the reply!
    F1nut Posts: 51,774
    Hope you bought ear plugs.
  • jj1127
    jj1127 Posts: 5
    Indeed. I've had the speakers for a little over a year now, but didn't realize they weren't really getting much power to actually perform like they can. I got fooled by the "2 channels driven" receiver lingo. Denon AVR-X4000 - great receiver, but on my rough calculations I think they're only getting like 40-50w per channel with all 5 channels going. Excited to see what this amp will do for me.
  • afterburnt
    afterburnt Posts: 7,892
    You should be fine for HT use. If you want music look for something else to drive your mains.
    F1nut Posts: 51,774
    jj1127 wrote: »
    Nope. You'll find out what I meant shortly.
  • jj1127
    jj1127 Posts: 5
    jj1127 wrote: »
    I guess I'm not following! I'll be hooking it up on Tuesday and I'll find out then.
    tonyb Posts: 33,072
    What he means is....the RTI speakers are a forward sounding speaker, a tad bright on the top end. The Emo amp can also be a tad bright on the upper frequencies, resulting is some listening fatigue.
    BTW....when you turn on an amp, any amp, it doesn't automatically throw 200 watts to the speakers.
  • jj1127
    jj1127 Posts: 5
    edited March 2016
    Gotcha - thanks. I'm an audio newbie other than doing the research I can and buying what seem to be and I hope are great products for my budget. Hopefully Audyssey will take care of some of the calibrations for me on those speakers and I'll adjust the rears accordingly after. And I think I understood that - just that it will provide up to 200W per speaker as required, but not always run at 200W. Thanks again everyone.
