Enable carp storm, fire on my command!
  • afterburnt
    afterburnt Posts: 7,892
    Nothing can be set up properly in this room. I am not swapping speakers i just want to hear them positioned differently.tis room is all windows doors and openings to other rooms so there is virtually no choice where stuff goes
    afterburnt wrote: »
    Many of us have those same limitations. You just have to find the right speakers to overcome them.
  • afterburnt
    afterburnt wrote: »
    ear buds
    Hey ya know.....to some cans are the solution.
  • mikeyb128
    mikeyb128 Posts: 2,885
    My 705's required some fiddling with placement. I found moving them forward away from the wall even a few inches helped tremendously. And toes in ever so slightly helped big time. But I get obsessive with things.
    I even ran out to homedepot at 930 pm to buy a hole saw so I could run a amp power cord out the back of my rack.
    2 channel:
    Theater:
  • afterburnt
    I guess you don't have a shotgun
  • afterburnt
    I will have some longer cables soon and I will be able to move these speakers out into the open, they will kidda block the front door and the door to the exercise room but I dont use either one very much lol.
  • afterburnt
    afterburnt wrote: »
    Hey can I disconnect the jumpers and just run the top half?
    dont try this at home, it is a waste of effort unless you are trouble shooting a failure. boy did that sound bad
