Don't shoot! Any good?
okiepolkie
okiepolkie Posts: 2,258
edited October 2004 in Flea Market
Please don't shoot me for asking about these. I was just curious to see if anyone knows anything about them. I am needing cheap rear speakers and was wondering if these would work.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5722187265&ssPageName=STRK:MEWA:IT
I have been watching the forum and ebay for Polks around this price range, but everyone else wants them too.
Tschüss
Zach
Post edited by okiepolkie on
    F1nut Posts: 51,760
    edited September 2004
    For that price you don't have much to lose.
  • Pauly
    Pauly Posts: 4,519
    I was actually looking at those a while back when i was gonna do a cheap 2 chnl office rig. but changed my mind. Yeah i would say for that price you cant beat it. What duty you looking to use them in?
    Life without music would
  • brettw22
    brettw22 Posts: 7,623
    I have a pair of HK speakers that came with the HK seperates/bookshelf system and they're great little speakers. you don't have much to lose, especially for what they cost there.....
  • okiepolkie
    I'm actually going to use them for rear surround in a 5.1 system. It is kind of mix and match setup(mostly Polks).
    Right now I have an older Yamaha RX-V2092 that was given to me, a new set of LSi7's, an RTi6 for center duty(temporary till I can scrounge up enough dough for an LSCi), and a Polk PSW 250. I have a set of Infinity Minuettes right now for rear surround, but I would like a little bigger speakers for DD.
    I've been trying to find a set of RT15,25,35 for rear surrounds for cheap, but haven't had much luck yet, so I thought I might give HK's a try. For that price, I might be able to get most of my money back by selling them if I don't like them.
    Tschüss
    Zach
  • brettw22
    I wouldn't go that loud with them, as they are pretty small speakers, but if the intent is a temp patch to your system, I say $50 isn't enough to worry about (let alone worry about recovering by reselling them if you don't like them).
  • woodyjacobs
    woodyjacobs Posts: 706
    Hey there,
    I tried some of these a few months back for a small 2 channel rig and they are pretty decent...very similar in sound to the JBL n24 (the drivers look identical, although I'm not sure that they are). They are also surprisingly nicely finished...I would say better than the R10/R15 polks. They are also similar in overall size to the r10/r15, although the bass driver is of course smaller so they don't dig as deep.
    Tough to go wrong at this price and the sound is better than you would expect...they don't go real low and you might have to turn the treble down a touch (the tweeter is okay but not real smooth IMO)...but hey...remember what you are paying. And they really do look pretty sharp.
    Woody
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
  • dorokusai
    dorokusai Posts: 25,576
    Pick them up, why not. I'm a sucker for bookends.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    F em.
    You are a HAIR away from something actually decent. Why waste the forty some odd dollars on a bandaid? If you want to MacGuyver it, hit the thrift store, or go get the Best Buy $19.99 specials of the week.
    $40 should be a good 3rd of the way, to a MUCH better choice. God, the speakers I've bought for $120 or less, UNREAL.
    Cheers,
    Rooster
  • Toxis
    Toxis Posts: 5,116
    It's $50... why not just put that money towards the center channel that you need, then take the RTi6 (and it's other half) and put THEM in the rear of your setup?
  • okiepolkie
    Toxis,
    I had about decided the same thing. It will take a while to save up for the LSiC, but from what I know it will be worth it if I wait.
    I am more concerned with my front end anyway.
    I might consider the HK's to help a friend start a home theater. I'm sure they would be better than some of the $300 HTIB systems a lot of people get.
    Thanks for the help guys.
    Tschüss
    Zach
  • okiepolkie
    edited October 2004
    Waited it out and ended up with these tonight.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5723414137&ssPageName=STRK:MEWN:IT
    Unless they are completely unrepairable(hopefully not), they should definetly be better than the HK's.
    Guess I'll just have to wait a while on the center channel, unless someone wants to buy a very, very lightly used pair of black RTi6's for about $200.
    Can't wait till they get here.
    I hope it is okay that the smallest and crappiest looking things make me feel like a kid in the candy store.
    Tschüss
    Zach
