Axiom Audio M80 any expericences??
geppy1
geppy1 Posts: 3,076
Has anyone had any experiences with the Axiom Audio M80? Thanks
  • Joey_V
    Joey_V Posts: 8,600
    edited March 2016
    Owned the m22ti in the past. I have also helped my friend set up his bryston model t which are cousins to the m80.
    They are supposed to be made to be transparent or neutral. Multiple drivers for each frequency spectrum.
    You can really play them loud I bet. Sound quality is likely good but I have not heard the m80
    Myself.
