Help! My interior lights and A/C lights are flashing with new amp and polk speakers, lights dead!
MMPolker
MMPolker Posts: 17
My rear exterior lights are out, the fuses are fine. blinkers work. My interior lights flicker to the bass thump at higher volume, and my ac unit is intermittently flashing on and off, but still works fine.
I connected every single wire correctly, except there was 1 wire that said "illumination" which i dont think matters because thats for the stereo to dim with other dimming lights.
Do i need to wire the black grounds to the head unit's chassis? Whats going on?
3 yellows connected together, 3 reds, 3 blacks.
45w rms x 4 alpine ktp-445u amplifier
22w rms kenwood dpx502bt
Polk mm651 speakers (4) 100w rms max 200
Answers
  • MMPolker
    MMPolker Posts: 17
    I swear to god I've been lied to by everybody. Everyone, professionals, told me I wouldn't need a capacitor. "It's too low to matter". Bogus answer.
  • MMPolker
    MMPolker Posts: 17
    edited March 2016
    MMPolker wrote: »
    My best guess is that the hazard light connector has become faulty in some way, causing my rear lights to stop working, and I know this because when I disconnected it and went for a drive, my blinkers stopped working. I plugged it in and my blinkers started working again. Plugged it back in while the car was on btw.
  • MMPolker
    MMPolker Posts: 17
    Is anyone here???
  • Nightfall
    Nightfall Posts: 10,083
    Your lights dim when the bass hits because the amp is drawing more power than your alternator can provide, either because it's a low amperage alternator or its useful lifespan is coming to an end. A capacitor won't help much, you need a new and/or more powerful alternator
    afterburnt wrote: »
    Village Idiot of Club Polk
  • trj
    trj Posts: 320
    Listen to Nightfall, he is guiding you to correct path. Capacitor won't do much if alternator is not able to supply to store in the capacitor.
    But need for information too. What car? What kind of battery? How old is the battery? How is the wiring?
    Grounded properly?
    Are you sure you are not shorting onto something?
    Plus, newer cars have everything computer controlled. You really do not want to even change the gauge of wire, it can cause havoc on the other components. How do I know? I retrofitted memory seats, autodim mirrors, auto headlights. And couldn't get it to work correctly because I was using slightly thicker gauge wires and wasn't twisting them enough.
    I have had my fair share of auto sound nightmares, so now I just live with what the car comes stock. But I buy a car with upgraded sound system option than whatever is stock. I don't like tinkering with sound system in the car anymore. Its very rare that everything works perfectly. Plus with the new CAN BUS system, much of it cables are fiber optics. So I stay away from breaking them.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • MMPolker
    MMPolker Posts: 17
    Nightfall wrote: »
    Yes sir you are quite correct as I didn't consider my alternator as a possibility, which I should have since I've known for the past year that my voltage regulator is out. My lights work again. It was my hazard button connector. It must be a little loose inside of it, because all my running lights now work.
  • Agree with Nightfall that you need a higher amp alternator or a new alternator.
    Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
    Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
    Stuff laying around. Too much to list but don't want to sell either.
