Best ceiling speaker match
Strong Bad
Which ceiling speaker would best match my setup?
Everything is from around the 2000-ish time frame.
RT800
CS400
FX500
RT35
I'm going for a single set to move into Dolby Atmos / DTS-X.
Thanks,
John
RT800
CS400
FX500
RT35
Thanks,
John
No excuses!
I'm thinking it will not make much difference with ceiling speakers and the small amount of audio they will add. I'll probably do some in the ceiling, likely 4 and will go with the most efficient and best looking for the ceiling match.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
John,
The best speaker now to match with the older RT series will be our Vanishing Series RT line. So the 90-RT, 70-RT, 620-RT. They use silk dome tweeters like the vintage RT series.
