Shadows And Light Available in Audiophile 192kHz/24bit & 96kHz/24bit
I bought this disc thinking it was the HDCD version but it is not even though it came up in the Amazon HDCD listings. And I cant find it online anywhere.The above is from HDtracks. The P5 that I ordered limits USB to 96kHz/24bit. What will happen if I buy the 192kHz/24 version? I have never ordered from HDTracks.
  • afterburnt
    afterburnt Posts: 7,892
    I should have just asked which one I should order?
    heiney9 Posts: 25,432
    The big question is........what does your player or dac decode? If you can't utilize the higher data rates, why pay for it?
  • afterburnt
    The P5 that I ordered limits USB to 96kHz/24bit I think that the Oppo DAC will do 192kHz/24
  • afterburnt
    How will the P5 handle the higher bitrate,or will it handle it at all? I could just order the lower bitrate l am sure that would work with bith DACs
  • afterburnt
    Well I just started to read something saying that 192 could sound worse.
    txcoastal1 Posts: 13,512
    I couldn't find the info on the particular remaster
    When shopping and downloading hi-res I try to research the native format at remaster and download that format
    Now if you want the 192 get it and run through the Oppo dac
  • afterburnt
    ok thanks, I will just get the cheaper one. I really wanted the cd but it is hard to find
