It's snowing out and I thought of biwiring
Willow
Willow Posts: 11,244
I own AQ indigo cables and thought of biwiring. I have what appears to be 4 strands of each. Does it matter which two I use of the -/+ for HF and which two for LF? Or do I just pick any two pop on some spades and away I go?
  • polk500
    polk500 Posts: 1,171
    edited February 2016
    Hello Willow,
    I maybe don't understand your question, I bi-wire my speakers cuz each speaker wire consist of 2-12 awg twisted and solder together making one 9 awg wire this is connected via banana plug to the red + and another to black - on the amp side.
    On the speaker side and this is what I think your asking does it matter where you wire it LF or HF? I've read that if you change it up it sounds better!! I've tried it both ways and I couldn't hear much or any difference which don't mean much as we all hear things differently. Also the power is still coming from the same channel so maybe that why and I had good wire jumper before as well.
    Cheers
  • Willow
    Right now I'm using xlo jumpers but have been thinking of biwiring. Except I have 5 black and 5 red wires so how to split them, 3 to bass and 2 to treble?
  • polk500
    That's what I would do. And for what it worth the reason I when with bi-wiring is like you the wiring is already in place and it eliminated the jumpers...
    Cheers
  • Willow
    Might give that a try if we're snowed in again tomorrow
    F1nut Posts: 51,912
    You would need another run of speaker cable to bi-wire.
  • Willow
    So there is no splitting what I have. That's what was stumping me. Kept reading stuff on the AQ website and couldn't make sense of it.
    F1nut Posts: 51,912
    There's no point in splitting what you have, it wouldn't be bi-wiring.
  • polk500
    I wonder why that is, you would think that the leads seeing how they all come from the same point either negative or positive would carry the same current would be perfect for bi-wiring.
    Is it because of the way they are designed?
    Cheers
    F1nut Posts: 51,912
    All he would be doing is reducing the wire gauge by splitting the wires resulting in less bass. Now, if he used a second run the wire gauge stays the same top and bottom.
  • polk500
    Makes sense.
    Cheers
    That sums it up in a nut shell.
