Need Help - Wall Outlets
So I'm trying to find angled wall boxes so I dont have to make 90 degree bends with my powercables. I know they HAVE to be out there, but all I can find is stuff thats a bit too pricey IMHO.
Now they just need to be empty boxes as I have some PS Audio outlets on their way in, but I need 2 of them, one for each side of my rack.
Anyone have a line on something cheaper than these?
    tonyb Posts: 33,072
    Dan....your looking for cheaper than 20 bucks a shot ? Sounds pretty cheap already if you ask me.
    EndersShadow Posts: 17,704
    tonyb wrote: »
    Yeah, but its also a lot bigger than I need and has extra holes, etc....
    I'd be ok with a single gang angled box so easy to install a caveman could do it :smile:
    pitdogg2 Posts: 27,040
    edited January 2016
    http://www.cyberguys.com/product-details/?productid=65898
    Dan google this "Recessed TV Box with Angled Openings"
    and you will find smaller but more expensive....you choice bra. The link I provided is cheaper but not much. If the hole on the bottom is what you are referring to there are plugs you can get to plug it. hit me up I should be able to get you the company and they give free samples I have used them before to get free items.
  • GlennDog
    GlennDog Posts: 3,152
    I didn't realize that that was even an option . . . Very cool
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Theheadsn
    Theheadsn Posts: 413
    Also look at Monoprice.com they may have a few things
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
