driver for RTA12C
soundfreak1
Need a driver for my RTA12C'S , MW6501 if anybody has one I'd appreciate it very much
Can't play my babies. I know polk has a replacement (not sure of the # but would rather have the original. (Just anal I guess).
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I have one if you're interested but it looks like it might have had a fiber gasket on it at some point. P.M me if you are interested and I can send you some pics.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
For what ever reason I can't find a way to pm you. I click on your name but no drop down. Pm me your email and I will contact and then you can send me picts. Never heard of fiber gaskets.Post edited by soundfreak1 onMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The fiber gaskets were on some of them if they were used mounted from the inside of the cabinet.The Model 10's I use to have had them on them.2 Channel
Oppo 103
Pangea PC
