s4 port sizes
I am building a center from parts ( mw7000) .
Does anyone have the exact port length and width ?
  • skrol
    skrol Posts: 3,442
    edited January 2016
    I have a pair and I'll try to remember to measure it for you.
    By the way, I am using a CS250s center that timber matches quite well with the S series in spite of being manufactured several years after they stopped the S series. The tweeter is a different number but looks identical and the woofers are of very similar build.
    Using the S4 components may give a little more body to your center than the C250. I have found that the S4 will chuff when pushed. A flange on the port may help.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,442
    I measured 3 3/4" for the length and 1 3/8" for the ID.
    Stan
    Main 2ch:
    HT:
    Other stuff:
