Music Hall Turntables?
  • WagnerRC
    WagnerRC Posts: 2,209
    George grand has sold me me so much great vinyl. George is awesome.
    msg Posts: 10,452
    gudnoyez wrote: »
    Don't store them flat stacked they will warp stack them vertical up against something like a wall or in those storage boxes SCompRacer told you about, all vinyl has a good chance of warping when stacked flat.
    wow, I did not know that! I would have thought the opposite.
    msg Posts: 10,452
    edited January 2016
    Thanks Charlie, I'll check this stuff out.
    what do you like better about them?
    chumlie wrote: »
    Here is the jacket sleeves and IMO there inner sleeves are better than the MoFi.
  • voltz
    voltz Posts: 5,384
    Every time I buy a used Record and most of the time I but a new one... I clean it and put it in a new Sleeve and toss the old one or keep the old sleeves with stuff on them in a box.
  • chumlie
    chumlie Posts: 8,658
    msg wrote: »
    chumlie wrote: »
    Stiffer than the mofi inner. Easier to pull in and out without the corners getting crumbled up. Outer sleeves are super thick and fit every album.
    gudnoyez Posts: 8,172
    msg wrote: »
    gudnoyez wrote: »
    How many record stores have you gone in and seen records sitting flat on top of one another? I hope none, I usually hold them up flat with fingers on the label and check for warpage before I buy em.
