Legacy
tonyb
tonyb Posts: 33,072
Seems they came out with a new one....the V. Looks like it has a more advanced form of an SDA processor too.....with a built in pre amp/dac.
Not crazy about the looks, the Aries is much better looking. I'm also not crazy about having a loud speaker do things other than what it's suppose to. But hey, don't judge a speaker by it's cover eh ?
http://legacyaudio.com/products/view/v/
  • erniejade
    erniejade Posts: 6,321
    It seems like more speaker companies are doing more with dsp or even smaller powered speakers. Since I have been dealing with bad room acoustics, I wouldn't mind more on the dsp side of things.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I dont believe one should put ice cubes in their glass of wine in the same way speaker manufacturers should put ice amps in a pair of speakers.
    tonyb Posts: 33,072
    Not a fan of powered speakers either but I believe Bill at Legacy wouldn't do it unless it was up to his standards.
    You better chill that red wine then, a good Cab should be 58 degrees when served. Brings out all the tasting notes in the wine. Poor 2 glasses of the same wine, one at room temp and one chilled to 58-62 degrees and compare.
