Speaker wire
Looking for a set of speaker wire can be anywhere from 4 ft to 8 ft with bare ends. Doesn't have to be top quality either, just decent sounding. What do you guys got in your closet ?
  • I have a couple pairs of 12ga Furez that Doug sells. It is like $.88' I think. You can have it for the cost of postage. The lengths are about 56".
    – Kevin Alfred Strom
    tonyb Posts: 33,072
    Thanks man, but I have something similar in there now in that second system.
  • Gatecrasher
    Gatecrasher Posts: 1,550
    I have some frayed and oxidized lamp cords that I spiced together and then baked in my little sister's Easy Bake Oven I can send you if the wire the other guys offered to basically give you for free isn't good enough for you.
    You will still have to pay for shipping though.
  • mikeyb128
    mikeyb128 Posts: 2,885
    2 channel:
    Theater:
    pitdogg2 Posts: 27,069
    nbrowser wrote: »
    I've still got 2 runs 8 foot of unterminated Canare 4S11, one is in use for my center but I'm planning on putting a Transparent Musicwave cable there since they got displaced by the AVT3s.
    I might be game when you want to get rid of hit me up.
  • BlueFox
    BlueFox Posts: 15,251
    I think I have some Mapleshade Double Helix v2 with Plus that you can have for a 12 pack of good beer, or $20. These were my first speaker wire upgrade from Home Depot 12 gauge.
    http://shop.mapleshadestore.com/Double-Helix-V2-Speaker-Cables-with-PLUS-Upgrade/productinfo/DHELIX2-PL/
  • daboyz
    daboyz Posts: 5,207
    BlueFox wrote: »
    If Tony passes let me know. Thanks.
  • BlueFox
    That is more of a special in recognition of his fictional essays. :)
  • daboyz
    daboyz Posts: 5,207
    No worries. Just looking for a good 50th B-day present from my daughter. I could have her write you a nice essay. ;)
