Ceiling Hang Bookshelf Speakers.....Horizontal
Is there a way to hang bookshelf speakers, such as Rti4, Rti6, etc on their side from the ceiling? I have not been able to find brackets capable of doing this. Anyone have a suggestion? Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Denon 3800
Parasound HCA-2205A
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Have you considered the Atrium 4 through 8 series? Although marketed as "outdoor speakers" they sound great AND come with mounting brackets that may be used for wall, ceiling or 45 degree transition mount between the two.
polkaudio.com/home-audio-outdoor-speakers/l/202 -
make a wedge from wood, remove the driver, send screws through from the inside into the wedge and into the wall.
ohh and put the driver back in.B&W CM9Classé Sigma
